Max boost level on stock long block?
Adaraas
Central FL
16 Premium GT, 17 Laramie Cummins
Sometimes it'll knock sometimes it won't?! You should have no knock at all regardless of what time it is.
Plus I trapped 133@650rwhp so you're a little off with your guess
My Lund tune shows 0 knock on 93 from 5-13psi and no knock from 5-16psi on corn
It always adds 4-6* on 93 and 6-8* on my e85 tune
I'm pretty sure its false knock. It'll never go that high, a degree at most. I just don't know where its coming from.
Also considering its running more timing with Ken B vs my previous tune its making more power. I was making 650 before. None of my runs have been any good. Its either gotten wheel spin or I launch too soft.
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
Its amazing to me how people want to try to justify how the coyote is better than the LS series while not understanding pushrod 2v vs dohc 4v
I'm probably somewhere between 13-13.5 PSI and 700-750 on 93. It'll knock sometimes and other times it'll have no knock in the logs. I think 13psi is a good number though.
I personally wouldn't run 13-13.5psi on 93. That is what I run on 100oct and I have never once had knock even being tuned for 23.5 degrees of timing.
Adaraas
Central FL
Ken B says its fine for what it is. I'll talk to him about it I guess.
zaquhree
Orlando
2015 S550 GT
Grab each IC pipe and aggressively YANK on it. Next time if we both are at OSW I'll once over it for you. I've gotten really good at tracing FK down.
