WD Pro
- Jan 18, 2018
- United Kingdom
- Lime GT
- Vehicle Showcase
- 1
I think I’ve got the jist of this, but I’m looking for some confirmation / sanity checks ... lol
So, if I understand correctly :
1 : The ‘standard’ wheel stud lengths (wheel mounting face to end of the stud) are 30mm front and rear.
2: The ‘MagneRide’ stud lengths are 36mm front and 30mm rear.
From what I have read, it’s considered OK to run a 6mm slip on spacer on a standard car (comments appreciated).
Based on that and the longer front MagneRide studs, could I safely run a 10mm or 12mm slip on spacer on the front of a MagneRide car ?
And finally based on 6mm rear / 12mm front slip on spacer combination :
Do the the 6mm spacers still allow the wheels to sit concentric on the hub ?
Are 10mm or 12mm slip on hub centric spacers available ?
Wheels are PP1 if it makes a difference.
I’m asking because I have a MagneRide car coming, I don’t like bolt on spacers, I don’t want to replace studs on a brand new car, but I would like it to fill the fenders a little better.
I know the changes I’m thinking about aren’t huge, but paired with the slightly lower ride height of a MagneRide car (see here post #15 : https://www.mustang6g.com/forums/threads/magneride-vs-pp1-ride.135168/), I’m hoping that the changes will be enough to be noticed and make a nice visual difference
Thanks for any help / confirmation on the above
WD
WD
