Magneride re-learn
Tripleyell
Ruskin, FL
2017 GT350 Grabber Blue
Has anyone here needed to reprogram or relearn their magneride for any reason whatsoever? I'm having a bit of an issue.
Tomster
Beware of idiots
Tom
I know the folks who didn't remove the spacers from their R models needed to recalibrate. What's up?
Tripleyell
Ruskin, FL
Car feels like a old town car with bad bags. Bouncy, and if you try to push it down by hand from the rear it barely moves down from how stiff it is.
johnny1
Had new a 16 GT350 and 17 GT350
Probably not this but could it be tire pressure. I got around to checking my 2016 350 about a month after I got it. Door jam sticker says 32lbs. all around but there was like 50 lbs. in each tire. Obviously factory may put more in them since they could be sitting for some time and when dealer preps them that is when pressure is reduced to proper inflation. Obviously my dealer didn't do that. But as said most likely not your problem. I noticed it didn't ride as rough after set properly.
xt6wagon
WA
2016 GT350 base triple yellow
You can check the tire pressure from the info screen.
dron_jones
Fell into a pot hole in Michigan and can't get bac
Me crazy, and I can't help myself
Beyond unhooking your battery and hooking it back up and see if anything resets i don't know what else you can really do beyond taking it into the dealership.
TDC
Long Island
2016 GT350, 2019 Challenger Scat Pack Widebody, 2019 Corvette Grand Sport
I've actually found if the tire pressure is 30 or below the car feels very soft. 35 seems to be the sweet spot.
OP, does changing the modes change the suspensions behavior or is it horrible in each mode?
Tripleyell
Ruskin, FL
Modes won't make a difference. I'm not getting any codes or malfunction.
Tomster
Beware of idiots
Tom
I don't know the recalibration procedure off the top of my head. It involves putting it on a lift and getting all the weight off the wheels. If you can't find it in a search, you might just want to take it to your dealer
Tomster
Beware of idiots
Tom
stanglife
Jeff
1993 Coyote Coupe
Hey neighbor. Did you just get it? Any chance the spring spacers are still in the front? That could cause the rear to be bouncy, as well. If you have an R - they came with spacers in the rear as well.
Tripleyell
Ruskin, FL
No spacers. So much contradiction though about Learn on the ground, off the ground, etc...
