Lund tune + thermostat
redline727
Thread Killer
Mooresville NC
Rocky
2021 Oxford White Mustang GT
mustang_guy
United States
it has an engine!
Several of us have done it from the top without even draining the system. I used a clear plastic bag (recycling) to catch the coolant while changing the tstat. 10 minute job taking my time, no water left anywhere and no need to lift the car.
Sent from my SM-G928T using Tapatalk
Out of curiosity how much coolant did you end up catching? 1qt-1L ish?
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
Just finished installing everything. It's very easy and no need to drain the radiator; I used a $8 clamp that I took a pic of too. I'll post the pics soon. It took around 30 mins.
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
Below are the pics. I did not drain the radiator. I used a hose clamp and as you see from the pics, I didn't lose much fluid. You will need to remove the air intake to be able to access the thermostat housing. There are two 8mm bolts that you will have to remove in order to remove the thermostat.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
silver.gt
2015 silver gt
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Thanks a lot for the pics. I see you like to live dangerously my friend lol traction control off with a super charger :headbonk: I would like to know what that feel like to :headbang:
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
Lol, I always have advance trac off. My car isn't tuned for the thermostat but the temps averaged 10 degrees lower.
silver.gt
2015 silver gt
I guess even if not programmed it still helps a little then
silver.gt
2015 silver gt
About that that's another question I have, if I remove the tune lets say I trade in my car o sell it w/o the tune do I have to put the oem thermostat back on? In other words if I just leave this one on would it affect the car in any way (w/the 160 and no tune)?
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
I would just leave it in if you trade in your car.
D3adch1ld
Blabber Mouth
New York
Marcos
15 Mustang GT Premum w/ Performance Pack
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
That's even easier.
D3adch1ld
Blabber Mouth
New York
Marcos
This is how I plan to do it as well. I have no desire to remove the PP splitter under tray if it is not needed. Thankfully you can do the oil change without removing it as well.
Question, is the coolant pump mechanical or electric on these motors? I never thought to look. I assume mechanical as I did not see anyone mention the bleeding procedure sequence to activate the pump with the engine off.
Mechanical.
beefcake
Bethel
2018 Ford Mustang
you can always pull the abs fuse too when at the track if you don't want to keep hitting the tc switch
