Looking for how to adjust hood center height
HoosierDaddy
Randy
I remember seeing a thread a while back that showed how to adjust hood front center height but can't find it now. Can't find something elsewhere either.
Drewbo
WTF?
Sydney
Drew
2016 GT Fastback 6MT DIB
DropTopBob
Manassas, VA
Bob
2017 EB Conv, Perf Pak, Borla Sport Axleback
I raised the hood by adjusting the latch up to its highest position AND by placing washers under the catch attached to the hood. However the hood-to-bumper gap is narrow at the center and wider at both ends near the headlamps. There is no adjustment to fix that (shy of a body shop) which is why I have the Hood Bra.
HoosierDaddy
HoosierDaddy
Randy
Thanks.
Mine is not off a lot. I might try the washer. Or I might try lowering the ends instead and assumed they were just rubber caps on a stud that could be threaded in and out. But it doesn't look like the rubber comes off and when I reach under, its rubber there too, almost like a single piece of solid rubber or rubber coating.
HoosierDaddy
HoosierDaddy
Randy
DropTopBob
Manassas, VA
Bob
My hood is now level with the bumper at center and both ends but my problem is the gap is close at the center but noticeably wider at both ends. From everything I’ve found this cannot be adjusted and seems to be how the bumper cap was molded. I’ve seen other Mustangs with a close, even gap and others worse than mine! My hood bra conceals the unevenness.
The solid rubber bump stops at either end don’t affect the gap either way but after I adjusted them up about 3 turns each the dreaded hood-flutter at higher speeds was eliminated.
HoosierDaddy
HoosierDaddy
Randy
Think you are right about that based on the how tos for R&R the bumper. I guess I should consider myself lucky my gaps are the same across the front.
I can't figure out how to adjust them. Is it as simple as just twisting them by hand? I was looking for a way to pull the rubber cover off to access a lock nut.
DropTopBob
Manassas, VA
Bob
Yep, twist those rubber bump- stops by hand
