Long Tube Headers
kodypiccirilli
Arkansas
Kody
2015 Twin Turbo Mustang V6
zackmd1
Zack
As far as I know, any header for the 11-14 generation will work with the 15-17s.
Curious to know how you will integrate LTs with the turbos?
zackmd1
Zack
Just throwing around some ideas for right now. Might be able to do bottom mounted turbos with LT headers to allow boost to hit the engine later as well as better exhaust manifold flow
I would honestly go with shorty headers and then fab up custom downpipes and have the turbos mounted a little lower then where the OEM Cats are. I believe we have talked about this before! Biggest problem with this setup is now you will likely need a scavenge pump in order to properly drain the oil as the turbos will likely be below the oil level.
