roryedits
Alright i guess ill head over to ford now and have them take a look at it and get it fixed if its covered.Cats shouldn't go bad, especially not at whatever mileage you have on your 17. They are a legally required emissions control device, definitely covered under the factory 3/36. There isn't a point to replacing them really, but I would always recommend getting the work done NOW in case it is a sensor issue and not a cat issue. If it is sensor related, could be the sensor, the fuse, or the wiring and you don't want to be responsible for chasing that down - especially after modifying it further.
Either route for bbk h pipe or fabricated setup works, just ask the shop in advance. If they aren't the greatest fabricators, get the bbk pipe and then have them adapt the rest of your piping to fit. The further back your issues are, the easier they are to deal with later on.
Heat wrapping can work but it can also introduce another point of failure and trap in moisture.
