LOC and stock sub hook up
Socal Stangman
California
David
So Im adding a sub to my stock system. I will be using an LOC and I know you usually tap into the rear speakers. I want to tap into the stock sub-woofer. What wires would I tap into to Mae this happen?
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
Why are you using an LOC? There are many Great quality amps out there that accept high-level inputs. Also, you’re better off pulling your signal from the front speakers to get the full range. Ford equalized the car for their crap speakers.
Do you have the B&O system since you mentioned stock sub? If so I’d recommend the PAC Audio Amp Pro interface.
Socal Stangman
Socal Stangman
California
David
Its temporary. Im using a 20.00 LOC until I take it all out and replace it. I will probably won't be doing this until late winter or maybe even early next year. Until then though I want to at least have some decent bass in my car. The stock system completely sucks and I won't use any of it when the time comes...
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
Ok, but is your system B&O? If it is, ditch the LOC and get the PAC Amp Pro. You can run your amp off it’s dedicated sub channel and then use the front/rear channels when you do your build.
Socal Stangman
Socal Stangman
California
David
Oh no, sorry it's not. Its the standard 9 speaker system.
Vicr
Fortuna Foothills, AZ
Vic
2015 Mustang Ecoboost Premium
This has been widely discussed. I would do a search, the 9 speaker system may have a different wire harness than the 12 speaker and you may or may not have the wiring in place for a stock sub.
Vicr
Vic
