Linear Spring for Ecoboost HPP
Blu22HPP
Minnesota
22 Ford Mustang Ecoboost Premium HPP
Anyone Ecoboost owners out there using minimum drop springs?
I have been contemplating the Steeda minimum drop springs as I'm trending in the linear direction. However, I'm guessing with the 1/2 inch drop, that will be less on the Ecoboost up front. I've reached out to Steeda and they have suggested the dual rate, which give me a little more drop, but my concern it would be a little more harsh on the ride. I'm looking performance first, but I want to keep some comfort as this is more a street car than a track car. I want it to be comfortable for the occasional road trip. I know the progressive option is always there but ...
FUN2RIDEFAST
Ofallon, Missouri
2017 Mustang GT Premium/PP
I too like performance over ride. I'm running Ford Track struts and shocks with Steeda linear springs and I like the setup. Tires are 305/35/19 & 285/35/19. My car is weekends and car shows only so I put Cup 2's on the car and it's night and day from any other tires I've run. I absolutely love it. Good luck with yours.
Steeda-Sergio
Valdosta, Ga
Sergio
2018 Ford Mustang Ecoboost, 2016 Jeep Grand Cherokee, 2022 Suzuki GSXS 1000 GT
The Dual Rates are very comfortable, but it is a performance-oriented spring. If the roads you're traveling are in bad shape, then they may feel a bit harsher.
The Progressives Springs would be the most comfortable option between the 3. Check out the attached links for both of the Progressive Options (non-Magnaride/ with Magnaride)
Steeda 555 8210 Mustang Sport Lowering Springs - Progressive (15-26)
Steeda 555 8242 Mustang MagneRide Sport Progressive Lowering Springs (15-26)
We are having our Memorial Day Sale right now, so now is a great time to grab a set.
Sergio Feliciano
Sales & Support
Semper Fi
Bilingual (English/Spanish)
Toll Free: (800) 950-0774
Direct Phone: 954-718-6515
[email protected]
2019 Steeda Way
Valdosta GA 31061
ISO 9001:2008 Globally Certified
http://www.steeda.com
Confidentiality Notice: This email and any attachments are for the sole use of the intended recipient(s) and contain information that may be confidential and/or legally privileged. If you have received this email in error, please notify the sender by reply email and delete the message. Any disclosure, copying, distribution or use of this communication (including attachments) by someone other than the intended recipient is prohibited. Thank you.
S550HPP
PDC
2022 HPP Vert
More wheel poke and PP1 dampers (same as Ford Performance Street Dampers) with HPP springs is perfect balance of wheel gap, handling and performance.
EIBACH front sway on full soft Plus 24mm rear Ford sway make a huge handling difference.
Ride is very smooth, corners on rails, looks lowered.
Blu22HPP
Blu22HPP
Minnesota
I'm not much of a fan for spacers, but did change up the wheels already to a 33 offset, which helps push out more. I also went from the factory 255/40 to the 265/40 to add a slightly taller, sidewall which has helped with the ride. While browsing this topic, I've seen several responses you've mentioned as well, that have been helpful in the thought process. Ideally, I'm trying to do this once, but right, out of the gate.
S550HPP
PDC
2022 HPP Vert
I wouldn't do spacers either. 265-40-19 helps.
