Let's talk Lug Nuts !
MikeD1
MikeD1
Central FL
2016 Challenger Hellcat
Hi Rob,
Greetings from Australia.
Would these 96643BDX be suitable for the MRR M350 wheels? (I've just bought a set of M350's and sorting out lug nuts is beating my brains out.
Also, is a specific "installation tool" required?
Many thanks,
Jim
If the MMR wheels work with the OE lugs, then these will work as well. Some aftermarket wheels require different lugs, so I'd double check with MMR if you're not sure or they didn't specifically state the OE lugs are OK.
These are 'spline' lugs, and come with an adapter (i.e. a key) that is needed for install/removal ( you can order a spare for like $15 from Gorilla I believe).
Adaraas
Central FL
16 Premium GT, 17 Laramie Cummins
MRR wheels do not work with the stock lug. You need a 14x1.5 Acorn seat.
e: the M350 specifically I mean. dnno about their other wheels.
I have these, except in black. http://www.amazon.com/Duplex-Spline-Drive-Acorn-14x1-5/dp/B008RPW5E4
I wouldn't buy them again though as I've started scraping the finish off of them.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
The M350 doesnt use the factory lug nuts
a normal 19mm socket size 14mmx1.5 acorn seat lug nut will do, any shop will have them for sure brotha.
Also no reset tool needed.
RSPEC-015
Sydney, Australia
Ford Territory & Mustang GT
Thanks Paul,
Last questions on this subject:
1) Will 22mm hex be OK instead of 19?
2) What is a range of suitable lengths: 1.45" to 1.9"?
Reason is I've come up with a lot M14x1.5 ranging from 19 to 22mm hex and differing lengths.
Cheers,
Jim
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Thanks Paul,
Cheers,
Jim
Standard length brotha 1.49" is the shorties we use. Also i use a 19mm socket or 20 mm
RSPEC-015
Sydney, Australia
Thanks Brotha,
That helps me out; looks like something similar to Gorilla 71643NBC is the way to go for the aftermarket wheels.
I think I can stop being a pest now!
Cheers,
Jim
Stripes
Greater Toronto Area
15GT 401a + Roush AB, MRT H-Pipe
For the life of me, I cannot find a set of splined red gorilla lugs in M14 x 1.5 ... Any suggestions?
Jon|3.7
Houston, Tx
15' 3.7 Mustang
which gorilla wheels locks will fit my avant gardes? 14mmx1.5
wasnt able to install them because of some crazy stuff but everything has calmed down and ready to installl everything on my car
aham23
FPC 5.2
Phoenix
22 FJG Mach 1 w/ HP
how does one protect the lugs when putting on and taking off? wrapping the inside of the socket with anything? much thanks.
