Least invasive Forced Induction Install
armsdealer
Baton Rouge, LA
2019 Kona Blue Mustang GT Premium PP2
I bought a 2015 Mustang GT with Performance Pack on impulse after one of my buddies was looking at them. The amount of money being taken off and 0% interest for 72 months make this a sports car on a Camry payment... well the Payment is less than my $22000 2013 VW GTI!
I was sold on the Ford Racing Supercharger at the dealer, but they couldn't do it, I would have to get someone else to install and I just dropped it and would get it done at the local certified dealer in my town. Well, Luckily I read the instructions to install it, and it is a pretty invasive install for what should be a simple Bolt on project.
Anyway, I would be happy with the power claims from Ford Racing, but I am not taking a grinder to my motor or cutting wheel to my K brace. It seems more invasive than need be.
That being said, what options require the least permanent modifications to the car? I have done plenty of turbo setups with no modifications needed, and even more turbo upgrades that integrated seamlessly into the existing system.
I haven't ruled out just a tune, but if I am swayed to FI, cause that is what I planned from the start after my brief moment of insanity thinking I was going to keep the car stock, I want something nice and reversible.
BLKONBLK2015
Lake Mary Florida
2015 Mustang GT PP
Whipple kit. Takes a day to install with basic hand tools. High quality kit, clear instructions, awesome drivability. Most invasive part is splicing the heater hoses, but really not that big of a deal.
armsdealer
Baton Rouge, LA
Beefcake, Lethal, this procharger kit is looking promising! Someone get me some quotes and details.
Process
Pittsburgh, PA
2016 Porsche 911 Turbo S & 2016 Shelby GT350R
Procharger and Whipple are the least invasive and easiest installs.
JoshMac
NC
2015 GT, 2003 Mach 1, 64.5 Coupe
Having requested the installation instructions from both Procharger and Whipple, the ProCharger is less intrusive. The Whipple kit requires some modifications that can only be
"undone" by buying replacement parts from Ford. After my review of both sets of instructions, ProCharger with the exception of having to "fish" the IMRC vacuum line back under
the intake manifold would be IMO much easier and less costly to return to stock. I know that the Whipple kit makes better power and driveabilty is better, but cost and ease of
install push me towards the PC. I'll be happy to share both sets of instructions if anyone is interested.
armsdealer
Baton Rouge, LA
How do you judge "Driveability" from one or the other. Is it in the tune? Procharger is available with Lund Tuning.
I am liking what I see from Procharger. This day and age, having a true bolt on kit shouldn't be an issue, I like that Procharger made their kit bolt on.
I have a manual, which seems to be a minority. I don't need the most power, I don't drag race, I just love forced induction...
AdrianMAK
Miami, FL
www.makperformance.com
2015 TY Mustang GT Premium
Procharger is the least invasive install, we have done them all. No wiring, no cutting, all is bolt-on. PM me if you would like a price, we are Procharger Distributors.
Here is our install thread when we did our Procharger Kit:
http://www.mustang6g.com/forums/showthread.php?t=15736
ProChargerTECH
Boostville
2015 Mustang(s)
Procharger. Cut nothing. Not a wire, hose or anything.
Boom. :)
I have personally uninstalled, and reinstalled a full system in 6 hours while doing photos for install steps. If ONLY every kit was that easy.
:headbang::cheers::thumbsup:
JoshMac
NC
The IMRC was causing some problems with tuning, the Whipple has a proprietary lower intake so that is eliminated. If going with a custom tune then obviously you can work with
them to get this fixed. I know PC has stated that 99% of tunes have been corrected and revised to make the IMRC transition completely unnoticeable. That being said, if I can
fully convince myself I need to boost this car, ProCharger is my choice.
I'm like you, I want a easily reverse able kit that makes good safe power. I want the stock clutch to live and the car be reliable. I bought it to DD the car so reliability is number 1.
I just need about 200 more hp........
ProChargerTECH
Boostville
2015 Mustang(s)
Stage 2 kit will get you plenty of HP, and smiles every time you floor it. :)
Easy to install, load tune, and rock and roll. :)
beefcake
Bethel
2018 Ford Mustang
we have some killer packages on the reg procharger kits, and our custom packages are unmatched!!!!!
Whipple SC
Fresno
There are only a few things that get modified that need replacement, but all the kits have parts that have to be modified.
We modify:
Passenger side plastic shroud, we drill a 1" hole for the IC hose to run through, with a grommet. This can be plugged later or left as is.
We cut the split loom around the knock sensor wire on driver side to give the wire more room for the new manifold (no cutting).
We notch the driver side radiator shroud close out at the bottom, a 1" x 2" piece that shouldn't ever need replacing.
We cut one heater hose on passenger side to remove the water restrictor and change the hose. This hose gets mended with the Gates heat shrink and plastic barb.
We cut the driver side heater hose to change the end. This hose gets mended with the Gates heat shrink and plastic barb.
The heater hoses can be left as is putting back to stock. So I'm not sure it can't be undone the same as the PC. The PC still needs to mount the IC and duct the air in and out, modifying the shrouds around the radiator. It's not a big deal, but we all have to do some modifying. Neither the Whipple, KB or PC require grinding the block.
