Latest Whipple Tune
The_Mad_Patcher
LI NY
Has anyone tried the latest Whipple update from June for the 2018 A10? How did it work vs. previous configuration?
Bluelightning
Bluelightning
North of Houston, TX
Lightning Blue 2017 GT350, 2019 F-150 4x4 Ecoboost (Daily)
I'm running it, but I have a manual. It is much improved from their earlier tune, but I can't vouch for the auto part.
TripleB
Idaho
2015 GT Snack Pack- Whipple Stage 2
how does whipple notify their customers of tune updates? I have a 2015 car and I think my tune is from last year... is there anything newer?
Bluelightning
Bluelightning
You can send them an email, although I don't believe that they've had an updated tune for the 15-17 cars for a while.
TX-Ripper
SE Texas
2019 Mustang GT PP1 Whipple Stage 2 / 2018 F150 5.0 Whipple Stage 2
2018+: the newest one runs really good.
TimT
North Dakota
Tim
2018 Mustang Gt PP
I have the June tune, I went back to the previous one from May, I thought my power was down, and the hesitation was still there at the lower rpms. Did run both tunes on the dyno and they had the same tq. and max hp, but the May one seems to have more in the lower gears.
TX-Ripper
SE Texas
What did you make on the dyno?
TimT
North Dakota
Tim
2018 Mustang Gt PP
on the dyno jet it did about 660 on the mustang it did 604, running 91 with boostane,
The_Mad_Patcher
LI NY
Bump
rtg
CT
Rob
2018 GT PP1+
The latest tune is by far the best yet. Very "street-able", which is what Whipple's goal is.
Engine performance is very OEM like....smooth.
The transmission shift schedules especially in "S" mode need some additional work. Mostly when down-shifting into 3rd or 4th. It can bang unusually hard in either "D" or "S" modes, about 2-3 times out of 10. Annoying but still a great improvement over previous versions. "S" mode up-shifts also can use some additional tuning. Seems to hang in a particular gear too long at times. "D" mode is very much like OEM accept for the occasional down-shift issues.
FWIW,
Rob
TX-Ripper
SE Texas
There is an intermittent idle surge that whipple is aware of and working to fix.
Happens every once in a while if you start the car and throw it in reverse immediately. Idle hunts and car feels like it wants to stall.
If you guys have any issues with the tune make sure your contact whipple support through their ticket system.
rtg
CT
Rob
2018 GT PP1+
Now that you mention it I have seen this issue as well. I believe it tends to be more prevalent when cold. I don't recall seeing this with a warm engine.
Rob
Burkey
Australia
Bear in mind, there’s several 18-19s out there, completely stock, that stall at idle for “no reason” (meaning: cause not yet found but appears to be at least partially related to the inlet cams losing the plot).
TX-Ripper
SE Texas
We are talking about two different issues.
(My car has no stalling or idle issues after the car is running for 45 seconds or more)
