Kooks Headers Ticking
racingmason
NC
2017 GT Premium
I have about 200 miles on my 7/8 catted Kooks Long Tube Headers. I went back and rechecked all the bolts and they are all torqued properly. I have noticed under load with the windows down I hear a buffing noise similar to having only one window down in a 4 door car and it is coming from under the car. It's really pronounced when I am next to a concrete barrier or trees along the road. It only appears when the car is under load. Also, when I get on the car a wide open around 3000 rpm it sounds deafening at around the doors when passing other cars. I've checked every clamp and made sure the Borla exhaust and x pipe are lined up correctly. I originally thought it was rasp but it is at a different pitch than the exhaust out the quad tip borla.
Hoping to god the comtech header flange gaskets aren't bad.
CEHollier
Prairieville, La.
Charles
2015 GT Premium Magnetic
Sounds like an exhaust leak.
racingmason
racingmason
NC
2017 GT Premium
The only thing I can think is leaking are the factory clamps that come off the stock cats/manifolds to the factory resonator. I think I'll pull the exhaust tomorrow and replace those clamps with a stainless coupling and band clamps.
CEHollier
Prairieville, La.
Charles
I have seen vehicles with a cracked exhaust manifold. That ticked significantly.
Chad11491
Roswell, GA
17 Lightning Blue GT Premium PP
Spray soapy water on the collector, where it meets the catback, and at the heads. Let it idle and if you see bubbling there’s your leak.
beefcake
Bethel
2018 Ford Mustang
cracked manifold is pretty rare, i would go through and retighten all the bolts
racingmason
racingmason
NC
2017 GT Premium
Use a shop vac to pressurize the exhaust and check for leaks. I saw a tiny leak at the kooks mid pipe and one between the x pipe and the rear pipes. Sounds better but I need a new band clamp to replace one that was stretched out and wouldn't tighten down.
stevnoof
new jersey
2016 mustang gt base manual 3.31
This what my xpipe sounded like when it was leaking bad where it connects to header
racingmason
racingmason
NC
2017 GT Premium
That's where I thought the issue would be but it wasn't. The clamp used on there is meant for butt joints and it works very well.
