ahl395
I know one member had alot of "false" knock that was similar to our condition and ended up finding low compression and air puffing out of the oil cap when off/running. Seems rare that is the cause but still worth mentioning.I've changed plugs too but haven't checked compression. I suspect it's fine as the car had less than 10k miles and no behavior I'd attribute to serious damage.
Do you see knock under the same conditions as I am? Accelerating through the gears?
Edit I see you have an auto. When are you seeing knock?
My false knock is very similar. I can be just cruising at a steady speed and see +1-3 suddenly, slowly fades away. Also under light accel I can see between +1 and +4 sometimes. It's all semi-repeatable but also random. Torco doesnt seem to do much if anything to help it.
Unrelated, I also get some real knock sometimes. +1-3, the reason I call it real versus false, is it happens when under load. Usually at or near WOT. Due to shitty gas in my area, which is why I'm adding methanol injection soon.
