Keyed 12v source?
Kentucky
Darrin
2019 Mustang GT
Is fuse #33 (Run/Start)in the passenger side of engine bay fuse box a safe keyed 12v source?
NGOT8R
Adrian
2019 Bullitt
Use slot #23 in the fuse panel located behind the passenger footwell kick panel.
Kentucky
Darrin
2019 Mustang GT
I'm wiring up a NOS nitrous system and the fuse tap that came with the kit is not compatible with the interior fuse box. Need a keyed 12V source in the engine bay fuse box.
NGOT8R
Adrian
2019 Bullitt
If you’re looking for a switched 12V power power source for your arming switch, the fuse slot that I recommended above is what I used for my nitrous arming switch panel. The other fuse link will connect directly to your battery and then a relay under the hood. See this diagram in the link below.
https://cdn.shopify.com/s/files/1/0559/7269/2108/files/universal_system_wiring_diagram.pdf
NGOT8R
Adrian
2019 Bullitt
@Darrin Polston did you ever get your nitrous install finished up? I’m interested in hearing more about your system. Is it a plate kit or nozzle, what size shot and do you have any pics that you can share with us? Thanks
Kentucky
Darrin
2019 Mustang GT
Still in the process of getting car tuned for nitrous.
Kentucky
Darrin
2019 Mustang GT
Running into a problem with knock sensors reading zero on data logs. SCT4 and Livelink Gen 2 software​
NGOT8R
Adrian
2019 Bullitt
I gotcha. Sounds like you’re getting close. Hopefully it won’t be too much longer until you get things sorted out.
