Jacking rails and oem vert braces
Pandora, OH
2017 Mustang GT Convertible
Trying to find the best way to reattach my full length jacking rails after pulling the oem irs convertible braces so I can get car up in air on jack stands under jacking rails but the stock rear braces must come out for me to pull everything out to install new rear suspension. Problem is the braces sit under jacking rails and there will be a space there after pulling braces and don't want to bend jacking rails or shear off bolts due to gap left. Do they make shims for this? Thought about buying junk rear oem braces and cutting off just the 2 ends to bolt back up rear of my rails to work on it, but price of these factory braces are pretty high just to cut off the 2 ends I need?
Thanks,
ShadowYoteVert
Pandora, OH
Ok thought about washers but just wasn't sure they would work without wanting to mash those 2 small point load areas. I am running your rails.
Thanks,
ShadowYoteVert
Pandora, OH
Ok cool thanks for the info...will look at picking up some 1/4" thick washers then!
Thanks,
