Issues With MMR OPGs?
Black Dog
Looking For Trouble
In the Country
Fred
2018 GT Air Cooled Twins by Comp Turbo
Any members here seen any problems with the MMR Oil Pump Gears? Such as low oil pressure? Or other problems? Not trying to start a war just some honest feed back.
Laztug
Wanna run dyno slips bro?
COTUS
Calling out OKC #1 spot after axle back install.
no.
ahl395
Allan
Never heard of any failures or problems with any of the OPG manufacturers (except Ford, lol)
Black Dog
Black Dog
Looking For Trouble
In the Country
Fred
Thanks for the feedback. Have heard that they are a hit or miss. Shop told me that they had low oil pressure after installing these MMR gears switched them to another brand and pressure was back where it was supposed to be. Hopefully was just a bad batch. Are they made in the USA or China?
Schu
Las Vegas, NV
S550GTPP
Gear ratio is set... frankly I find it hard to assume it would lower your pressure.
You can't just arbitrarily change a years tooth pitch or count.
Mod Mustang Racing
California
www.modularmotorsportsracing.com
Worlds Fastest & Only 5 second Coyote
Our gears are hands down the best on the market. Our gears do not have ANY issues with oil pressure, in fact our gears are the only ones tested for flow and pressure (see our youtube video). Our gears have NEVER suffered from a single failure. Our gears are 100% USA made! Our gears can be found in many of the current and past NMRA champions including coyote modified and Renegade.
If someone had low oil pressure it was likely caused by leaving out the factory o ring when re-attaching the pick up tube or having incorrect pick up tube to oil pan clearance.
If anything our gears produce more pressure than the others on the market due to more precise tolerances. Our gears hold a tighter tollerance due to 100% CNC machine process, we DO NOT use the cheaper wire / edm cutting process like the others on the market.
Should anyone have any questions or concerns in regards to any of our products we can be reached at 1-877-MOD-POWR.
A big thank you to all of the members here that use the MMR products.
Black Dog
Black Dog
Looking For Trouble
In the Country
Fred
Thank you for this informative info.
Eco85
Mad Scientist
Northwest IN
Justin
2015 mustang
These gears are bad ass and rock solid! They survived an oil starvation due to a clogged pick up tube “ thanks oil level sensor” that tore my engine up, oil pump housing not so good but gears are in the rebuilt engine and make gobs of pressure. Thanks MMR :cheers:
beefcake
Bethel
2018 Ford Mustang
never seen or heard of a low oil pressure from a set of opgs, ever, and we have been around this for a long time,
shop is smoking crack
wildcatgoal
@sirboom_photography
TBD
Yeah... I'm gonna go ahead and say the shop installed the MMR gears wrong and fixed the mistake with the other gears. Let's hope they didn't fleece the customer even more by charging twice to fix an error they found they made during the second installation.
