Is this normal?
ryant601
'16 GT - Black Accent Package
I'm going to try wiping it down and seeing if i can get a clean slate to see how it develops.
EcoMax
NY
2015 2.3l Mustang Ecoboost
Any update on what could be the cause? I inspected my hoses bolts etc for a leak but nothing, it literaly looks like it is leaking out of the seam on the engine block.
Zemedici
Kennesaw, GA
Josh
2015 GT/PP
ryant601
I have a service appointment on the 25th for other stuff, I'll mention it then.
EcoMax
NY
Could it possibly be boost pressure getting into the crank case and pushing oil through the seam between the block and crank case cover? Check your throttle body and turbo charge pipes for oil residue inside of them also.
Edkiefer
NYC
XR4ti
Yes , doesn't even need boost . One symptom of bad blowby or bad PCV system is gaskets leaking that are part of crankcase/valve cover .
One of the Venders mentioned the PCV doesn't close 100% under boost , so that goes into crankcase .
Also new engines don't use gaskets, it just silicon used in many cases and can seep a bit .
juan_tony1
North Carolina
Juan
ECO DIB TANG
I have that same problem...and when I did my intercooler install I had oil residue on both pipes
EcoMax
NY
Check your pcv valve it may be malfunctioning.
WatchSquid
D/FW Texas
Jim
93 Reef Blue Mustang convertible
Clean your motor. It's a lot easier to identify a leak on a clean engine than it is through caked on dirt and grime.
marjen
2015 Mustang Ecoboost
Ct
2015 mustang Ecoboost premium
So my car was at the dealership today getting the recall taken care of. I asked them to look at the spot I posted at the beginning of this thread. They claim this is normal. It's some kind of seals "sweating" from something to do with rear differential? They claim they took a bunch of things apart and there is no leaking. Not sure I 100% buy the explanation but I now at least have it documented in case anything comes of it.
Turbo Ghost
Metro Detroit
Jeff
Ecoboost PP
Sounds like BS about the seals.
ryant601
Could be BS, but maybe not. I brought mine in and they deemed nothing was wrong (like they always do). Wiped it clean and haven't seen it again.
iljalop
Brooklyn, NY
2015 Mustang EcoBoost
Noticed the same issue on mine today.
Who can tell me what is better to use to clean it till bare material to have a closer look from the beginning?
EcoSwag1990
West Chester, PA
2016 Triple Yellow GT
What?
