is this the pvc hose? if so, why does it come loose so easy? is it normal?
Discussion in 'I4 2.3L EcoBoost Engine / Mods: Bolt-ons, Exhaust,' started by ecoboost2015, Apr 21, 2019.
  1. ecoboost2015
    ecoboost2015 Active Member
    First Name:
    Andrew
    Vehicle(s):
    2015 Ford Mustang Ecoboost
    Apr 1, 2019
    Nevada
    i was checking my charge pipes today, and notice that this one hose came loose by hand pretty easily, is it the pcv hose? is it normal for it to be loose like that? 20190421_160053.jpg 20190421_160223.jpg 20190421_160241.jpg
  2. Bear376
    Bear376 Well-Known Member
    First Name:
    Vehicle(s):
    2013 Mustang, 2013 Flex, 2017 F150
    Oct 9, 2018
    Stillwater, OK
    188
    86
    Garage Profiles:
    When you push it on, you should hear a distinct click. If you do not, it will not stay.
    Hellman109 likes this.
  3. OP
    ecoboost2015
    First Name:
    Andrew
    Vehicle(s):
    Apr 1, 2019
    Nevada
    Ok Im pretty sure it doesn't click in when I press it down. Ill check again in the morning. But my other question is, is this the PVC hose or a similar part ?
  4. Bear376
    First Name:
    Vehicle(s):
    Oct 9, 2018
    Stillwater, OK
    188
    86
    Garage Profiles:
    The first picture, the white slider on the piece that fits on the smaller tube is the latching mechanism. It is in the unlock position. if you push it in firmly, the slider will close with a click moving clockwise.
  5. OP
    ecoboost2015
    First Name:
    Andrew
    Vehicle(s):
    Apr 1, 2019
    Nevada
    Ok. But is that tube the PVC hose? Is that what im looking at here. I understand the white ring is a locking mechanism
  6. OP
    ecoboost2015
    First Name:
    Andrew
    Vehicle(s):
    Apr 1, 2019
    Nevada
    I don't think the white ring is locking in. From my understanding it would be easier to replace the whole hose than to just replace the ring. That's why Im trying to figure out if that smaller hose in all 3 pictures is the PVC hose
  7. Bear376
    First Name:
    Vehicle(s):
    Oct 9, 2018
    Stillwater, OK
    188
    86
    Garage Profiles:
    It is the PCV valve, but I do not know about replacing it. You would have to trace it to the other end and remove it to see the hose is part of the valve.
  8. OP
    ecoboost2015
    First Name:
    Andrew
    Vehicle(s):
    Apr 1, 2019
    Nevada
    Didnt you say it was the valve? Im not sure I understand what you mean
  9. OP
    ecoboost2015
    First Name:
    Andrew
    Vehicle(s):
    Apr 1, 2019
    Nevada
    Are you thinking it might be hard to locate the other end ?
  10. HoosierDaddy
    HoosierDaddy Well-Known Member
    Vehicle(s):
    2016 GT Premium PP and a few others
    Jan 2, 2016
    3,883
    1,571
    Rating:
    100%
    2   0   0
    He's just saying if the end is defective, you have to replace the hose because they are one piece.
  11. OP
    ecoboost2015
    First Name:
    Andrew
    Vehicle(s):
    Apr 1, 2019
    Nevada
    so you're saying I'd have to replace the whole pvc hose? the ring looks broken to me
  12. OP
    ecoboost2015
    First Name:
    Andrew
    Vehicle(s):
    Apr 1, 2019
    Nevada
    Im assuming you mean I have to replace the whole PVC hose since the ring is attached and cannot be purchased separately
  13. HoosierDaddy
    Vehicle(s):
    Jan 2, 2016
    3,883
    1,571
    Rating:
    100%
    2   0   0
    I'm just saying that's what I think @Bear376 was saying.
  14. Bear376
    First Name:
    Vehicle(s):
    Oct 9, 2018
    Stillwater, OK
    188
    86
    Garage Profiles:
    #14 Bear376, Apr 24, 2019
    Until you remove the hose, you do not know what are the issues. If the connector is bad, it has to be pulled anyway. If it is just full of crud, or something fixable, it should not be any issue to reinstall. The hose should be fairly short, with the same press on connectors at both ends. In the old days, they were just a ball check valve that was easy to test.
  15. OP
    ecoboost2015
    First Name:
    Andrew
    Vehicle(s):
    Apr 1, 2019
    Nevada
    well I found out that the hose while it might resemble the pvc hose, its actually a tube assembly of some sort, I'm going to try to get it click in, the white ring, hopefully it will lock in like it's supposed to. some parts source claim this is a fuel pressure line of some sort , I don't really know.
  16. OP
    ecoboost2015
    First Name:
    Andrew
    Vehicle(s):
    Apr 1, 2019
    Nevada
    this is the hose that we're looking at in my original pictures, the hose in this picture came out of a 2016 mustang ecoboost and its on ebay, I'm using it as illustration . the other picture is the actual hose in my car
  17. Bear376
    First Name:
    Vehicle(s):
    Oct 9, 2018
    Stillwater, OK
    188
    86
    Garage Profiles:
  18. OP
    ecoboost2015
    First Name:
    Andrew
    Vehicle(s):
    Apr 1, 2019
    Nevada
  19. War-Machine
    War-Machine Well-Known Member
    Vehicle(s):
    2016 Mustang Ecoboost Premium, Deep Impact Blue
    May 26, 2017
    Carmichael, CA
    61
    By the way, it's PCV not PVC :like:
  20. OP
    ecoboost2015
    First Name:
    Andrew
    Vehicle(s):
    Apr 1, 2019
    Nevada
    ok then, the hose we're looking it isn't the pcv.
Loading...
Share This Page
