Intermittent rough idle
fms 19’ Gt
South Carolina
Dylan
19’ Gt
I’m curious if anyone has experienced or diagnosed the potential cause for an intermittent rough idle while in drive or sports mode with a gen 3 coyote that has an automatic transmission. It probably started about 5-6 weeks ago for me. There has not been a single check engine light or code stored within the system. But between one to two times a week I’ll be cruising around, approach a stoplight and while I’m sitting there the RPMs will drop to about 400 and the engine will shake a little bit then jump back up to normal idle range, & won’t happen again for a few days afterwards. There’s been one instance where it’s happened while in park & that was about a month ago. Earlier this week, I had an instance where it actually became frequent during a drive-through downtown but once I turn the car off for a while and came back, it didn’t happen for another three days. I’m just very confused and would appreciate any reply and knowledge on the subject thank you in advance :)
ORRadtech
Atlanta, Georgia
Does it happen to coincide with a fuel fill-up?
The Evap purge valve can cause those symptoms if it's failing.
There are other things that can cause them too but it's the first thing I think of.
fms 19’ Gt
South Carolina
Dylan
19’ Gt
I don’t believe so, I’ll usually go 6-8 days between fill ups and haven’t noticed it directly after doing so… it could potentially be the fuel from this specific gas station though, I don’t really fuel up anywhere else. Thanks for sharing your idea, I’ll pay more attention next time I fill up the tank 👍
Coyotebawl
Lafayette, Louisiana
2019 Mustang gt
Had similar issues with my 19 gt last year, I changed all 4 VCT solenoids and has been good ever since .
Sig556
White18
North Carolina
Ed
2024 GT Premium / Iconic Silver 10 Speed Auto
Check your O2 sensors for carbon build up. They can be easily cleaned and not needing replacement.
