Interior LED Kit
Midnight_LMR
Midnight_LMR
Edmond, OK
2017 GT PP
let me see if i can find the link i saw in here to a PDF a guy put up. Can you tell me how long the dash piece is? And also on your pic it looked like you did just that removable section from center to passenger side correct? That and the footwells?
magnetticmadness
Southern California
2018 mustang gt premium OW 10spd
[MENTION=18458]Midnight_LMR[/MENTION] i cant say for sure right now but ill go check right now and measure it. yes i only did the center to passenger dash panel piece. and also the footwells.
Midnight_LMR
Midnight_LMR
Edmond, OK
2017 GT PP
ok thanks I appreciate it, each to their own but [MENTION=9987]Diode Dynamics[/MENTION] has earned my loyalty so I want to do this though them but apparently I will have to do it myself off their universal fitments cause they have failed to respond on this topic which is pretty unlike them
Midnight_LMR
Midnight_LMR
Edmond, OK
2017 GT PP
You used 41.9 inches of lighting for it?
SBLee29
Long Island, NY
2016 DIB Mustang V6 w/051a
[MENTION=19039]magnetticmadness[/MENTION] what I am planning to do is find out where they ran the original ambient kit to, I have the full wiring diagram at home just need to look, and then I will run it to the factory location that way it should turn on and off the same as originally intended. I saw the wiring diagram on here somewhere I think i DIY section
From what I remember reading you'dto tap into fuse #1 and that should work the way the other interior lighting does. I could be wrong
Diode Dynamics
St. Louis, MO
www.diodedynamics.com
2015 Mustang EcoBoost
Is there any setup of lights that you would advise could do what we are taking about here? Dash and footwells like what he did? Or can DD put a package together for interior lighting kit of some kind? I'm sure it would be a big hit
We have both single and multicolor footwell lighting kits listed here on our site: http://www.diodedynamics.com/store/led-bulbs-1/led-strip-accent-kits/footwell-kits.html
They are priced reasonably, and the strips produce exceptional output for even light coverage
Nick C.
isoto
Kansas City
2015 Mustang V6
Diode Dynamics
St. Louis, MO
It come with instructions how to install?
It's a universal kit, so we do have YouTube videos demonstrating the installation, here's one for the RGB kit:
[ame]
It's extremely simple to do, you're basically just tapping a 12V source and common ground.
Nick C.
Midnight_LMR
Midnight_LMR
Edmond, OK
2017 GT PP
[MENTION=9987]Diode Dynamics[/MENTION] thanks Nick for your response but what I was asking about was an entire interior kit like what [MENTION=14032]Magnetic[/MENTION]madness has built here. I know you guys have footwell kits but there is alot more to what he did than just that
Edwin
Butler, PA
Edwin
2015 Ecoboost Mustang - Triple Yellow
You guys might have it figured out already but if you buy a Mini add-a-circuit and a 10 amp fuse you can use that to connect your LEDs to the passenger side fuse box. Fuse #1 works well as its 12v switched. That's how I have my kit from LEDGlow installed. There's also a couple places near that fuse box to use as a ground location.
http://www.amazon.com/Pico-0956PT-Blade-Add-A-Circuit-Holder/dp/B001QRSBW0
