Installing CAI issues.
Bluemustang
2015 Mustang Base GT
The only performance benefit is improved tip-in throttle response (most noticeable when doing throttle blip downshifts).
Can you explain further? What does this mean?
Terminator2
Spring Hill Florida
David
2016 Mustang GT Premium
Would removing the sound tube be a bad idea for a 3 month old car under warranty? I don't want to risk losing any warranty repairs because they somehow claim the sound tube caused it? Would you guys keep it to be safe, or will having warranty repairs potentially denied because of the sound tube delete be a non-issue?
Other than a vacuum leak if not properly capped off on the intake tube a sound tube delete cannot possibly cause any issues.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Ok, so when you're blipping the throttle to rev-match downshift, you're starting from a relatively high vacuum with the throttle closed. The sound tube adds volume (but not in the place you want) to the intake system that negatively effects how much air can be pulled in with a throttle blip. You won't notice much at all if you have an auto.
2015Etrac
2015Etrac
PA
Black 2016 Mustang GT Premium 401a
Would there be any issues with pulling the sound tube from the CAI, plugging the intake hole, and then plugging the tube? This way I can leave it installed but non-functional and if I need any warranty work done I can just plug it back in the intake?
Terminator2
Spring Hill Florida
David
Nope no issues I just wanted the whole ugly thing gone lol.
BmacIL
Enginerd
Naperville, IL
That's what I did, essentially. See my build thread.
2015Etrac
2015Etrac
PA
Haha, yeah they are such ugly clunky looking contraptions. I don't know what Ford was thinking.
Terminator2
Spring Hill Florida
David
My focus ST had an electric one that played through the speakers. I unplugged it the first day I had the car. It sounded horrible like fake V8 sounds starting at about 3000 RPMs and around 25% throttle.
robertwsimpson
West Palm Beach, FL
Robert
2017 GT Convertible
you don't need to plug the tube as long as you don't remove the diaphragm. You do need to plug the intake port though.
tj@steeda
Timothy
We have a cost effective solution for you here
http://www.steeda.com/steeda-sound-delete-kit-2015-2017/
Once again you asked for it and the Team at Steeda delivered. We designed this kit for use with the OEM induction system on the 2015+ GT Mustangs. Lots of customers choose to get rid of the factory sound tube but have no way to plug the 2 holes left as a result of removing it. This simple kit comes with a rubber cap for the intake tube and a plug for the firewall making for a clean removal.
Benefit #1: Cleaner engine bay
Benefit #2: Lifetime warranty
Benefit #3: Make in the USA
Best Regard,
TJ
2015Etrac
2015Etrac
PA
Best Regard,
TJ
I think my Steeda CAI I installed today came with the caps?
2015Etrac
2015Etrac
PA
I was wondering that. I assume air can't get through the tube and into the cabin? So if I leave the tube installed but unplugged in the engine bay I won't have to worry about heat or fumes coming through the tube and into the cabin? I was thinking about putting some tape over the end of the hose just in case.
robertwsimpson
West Palm Beach, FL
Robert
2017 GT Convertible
no, you're fine. If you just remove the little bit of hose by the intake elbow, you only need to cap the intake side. There is a diaphragm that prevents air from traveling to and from the cabin. There's also a coarse filter in the intake tube right at the firewall. There is no way that anything is going to go in either direction if you just leave it there. Like I said, I did that for about a month or two.
