Installed Trans. Bushing insert, now lots of vibrations
lootinleoni
NW Indiana
2017 Mustang GT
I installed my transmission mount bushing insert....and since then driving now I’m definitely getting vibrations you can feel through entire car...not constant just light accelerations around town going around 25-45 mph...and below 3k rpms. But it’s kind of annoying and makes driving around town not pleasant like something is failing...I know NVH will happen to mods to improve suspension on these cars but damn...I might take it out unless anyone else has experienced this then I know I’m not making it worse for the car...any input or suggestions...
FightingFalcon
Germany
Oliver
2018 GT Auto
A transmission bushing is not part of the suspension! :wink:
Wich one did you use?
How did you install it?
What was your goal with the bushing?
Increased NVH is typical for many busings, especially hard ones.
jr1050
Swansea, MA
Jeff
2016 Mustang GT Premium Convertible
I installed ours last night and noticed the same thing, which was expected. We only got to try it on the way in to work this morning (wife and I work for the same employer) so we need more seat time to see if I should make any changes to it. My wife likes the feel of the shifter better especially on harder shifts.
My thoughts are that it may have a slight break in period to it so I want to wait it out.
One option you have is to remove it, then drill anywhere from a 0.5" to 1.0" hole in the center of the lower flat portion of the bushing and this can help reduce the NVH but keep the benefit to the firmer shifts.
Chef jpd
Brooklyn, NY
I did a little testing with a Whiteline bushing insert.
Whiteline was way too stiff. Drilled a few holes in the flat bottom.
That did a little to calm down the NVH. Then I fully removed the bottom flat portion and left the 2 upper portions. Much better and still stiffened up compared to stock.
SO, with that, I added the Steeda upper mount and bracket, did the Boomba short shifter, then did a fluid change. 1000% better shifting and never got the 1-2 nibble since.
GregO
Illinois
S550 GTPP
Amazing transformation from a few simple parts isn't it.
Care to mention what trans fluid you used ?
GregO
Illinois
S550 GTPP
The Steeda trans mount insert is the best of the bunch. I die punched a .875 hole in the center of the middle leg and chamfered the leading edge of top and bottom of hole.
Perfect amount of feel and near zero NVH.
Chef jpd
Brooklyn, NY
Royal purple syncromax.
chesster51
Middleburg, FL
Rick
2019 Bullitt
I understand the bushing really helps when using the stock shifter. I will be replacing mine with a MGW and was going to order this bushing also, but after thinking about it, now that the shifter will be attached to the trans and not the body, is it even necessary?
moffetts
San Mateo CA
Black Whippled 2015 GT PP
I’ve never heard of anyone using both. I don’t think the bushing will fit with the mgw anyway.
