Installed Manifold - Help!
cgiles
Upstate SC
2020 Roush RS3 Kona Blue
I'll prefix this with I'm a moron when it comes to cars. I know enough to be extremely dangerous but I like to tinker and I know the only way to learn is to make mistakes. I've made a mistake somewhere and my lack of knowledge and experience is showing.
My car is a 2016 GT that I recently installed a catback on. That worked fine, drove fine, went to Mustang week and back, no issues. I get back home and install a ported 18 manifold, 47# injectors, PMAS, a tune, and fill up with e85. I watched the VMP video and I think I had it all correct. After loading the tune the car runs like crap. I datalogged and sent to tuner and apparently my O2s never come on.
I'm running at 9.8:1 afr all the time, if I'm to believe the dash numbers. I kept the IMRCs and have been over all the vacuum hoses. I watched the Auto Mafia Racing video and that's how I have it routed now with the IMRCs still intact. Still runs the same. I thought O2s would come to life at a certain temperature. Why wouldn't they work? They are six years old but I can't imagine they both went bad on the first crank with e85. I checked fuse 40, which seemed to be a problem from my searching, and it's not blown.
What else can it be? Tuner wants me to lock out the IMRCs, but I don't think that will miraculously make my O2s work.
Edit: I had P2196 and P2198 codes. I cleared and they never came back.
Proshop
Billy
2021 Ford Mustang GT
Do what your tuner asked and lock them out! I could be wrong but I don’t believe the 18+ electronics for the IMRC are the same so that maybe your issue.
cgiles
Upstate SC
I used the Lethal pigtails to make them work.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Flash it back to stock then back to the PMAS tune.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
silverbullet85
San Diego
2019 Gt
Did you wait to fill up on e85 till you were as empty as possible? I ran mine on pump gas tune and as soon as the car started to run poorly I switched to the e85 tune and everything's good. I would try reloading tune like was suggested and go from there.
EFI
Masshole central
5.Br0
How can there be an AFR reading in the dash if the sensors don't come on??
Who tuned the car? I would say it's between a very poor tune (which I doubt if you used a good vendor) or you have a major vacuum leak. Have you checked all intake and manifold connections are good? Do you have any other codes besides the ones you cleared and never came back again?
K4fxd
NKY
It's in open loop. I've had this happen to me before when battery voltage got low during a flash. Charge the battery and flash to stock, then to the E85 tune.
cgiles
Upstate SC
I would need a tune. I only have a stock tune, e85 w imrc, e85 wo imrc.
Jackson1320
California
Jaxson
2015 mustang gt
reflash the tune and make sure the battery is fully charged before you do it
cgiles
Upstate SC
what is the procedure for applying the stock tune and then reloading e85? Leave car off or crank it after going back stock tune?
Proshop
Billy
What tuning device are you using?
cgiles
Upstate SC
Proshop
Billy
Sorry,
That would be a handy bit of information. I have a X4.
Been years since I’ve used an SCT device and on a different platform but doesn’t it save your factory tune before you use the aftermarket tune? If it does then flash the saved factory tune from the SCT back on to the car and then reflash your e85 tune. As for your AFR they are correct for e85 that’s what mine read at idle also.
cgiles
Upstate SC
I returned to stock tune and then reflashed the e85. It feels much better driving and the AFR now moves instead of being a static 9.8. I've logged and will send to the tuner to see what they think. Fingers crossed.
