Inside Rearview Mirror Shake
keltymd
Murfreesboro
2017 PP
Had this on my 14 and a lot of others had the issue too. If you wedge a small piece of plastic or paper between the mirror mount and the windshield it fixes it. The spring for tension is jsut not strong enough to prevent the vibration
15Pony
Jackson, MS
Bruce
2015 Mustang V6
I don't have lowering springs. So, what's causing it is the vibration of the body of the car. Nice job, Ford. :/
SYK
Atlanta
2015 EB Premium PP Auto
If you read my previous comment carefully. I had the vibration from completely stock car and it went away after Spring/Shocks.
15Pony
Jackson, MS
Bruce
2015 Mustang V6
Ok, so it seems like the stock configuration produces the right frequency of vibration in the car to make it shake but the new spring/shock setup changes it for the better.
SYK
Atlanta
Update:
Vibration came back. I will try to see if it is coming from driveline vibration. Will report back, team!
SYK
Atlanta
Only had 4mm shims. Shimmed 4mm reduced vibration to none in 0-75mph. still have vibration in 75 - 85. I will try to get around to 1/4" shim that seem like most people are having success with
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
I have it. GF finally noticed it on our recent vacay drive. I used flocking tape under the mount, too.
I think it is likely related to driveline vibration. I have that symptom, too, but it is mild enough not to obsess enough to try to fix it myself, or to take it in.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
I have this from 75-85. Not there below that or above, except right near 60. It's annoying and done it since day 1 of ownership. I've thought about adding a decent chunk of stick-on lead to mass damp it.
seth21w
Georgia
Seth
2016 Mustang GT base PP ingot silver
Vibration over bumps loud music etc...Normal Having to re adjust the mirror after a trip or anytime really, is not normal. Unless you are 6'4 like i am and bump your head on it and move it that way lol
Kong76
Turlock, Ca
2016 Ingot Silver GT
My mirror assembly actually rocks up and down. About 1/8 inch worth of slack. It shakes on the freeway but F it.
Hooch180
Europe, Poland, Silesian Agglomeration
Maciej
Ford Mustang GT 2019 5.0 (EU)
I guess it vibrates because it has resonant frequeny close to frequecny of other sources of vibrations (engine, road/tires, music).
I will try to add some weight to it to see if it changes anything.
