Input shaft bearing failure??
OnThree
2015 mustang GT
Hey guys,
Have a loud, almost like a clutch chatter noise on steroids happening with my 15 GT. Car had new McLeod RST clutch, flywheel, TOB, at 24k. The car now has 40k miles.
The car makes noise in netrual when the clutch is released, no noise with it engaged. The car is extremely loud in gears 1-4 but quites down in 5th. I'm thinking it's a shaft input bearing failure, any ideas how to diagnose before pulling the trans?
OnThree
OnThree
2015 mustang GT
Eliminated all the little things, gonna have to drop the trans now. :facepalm:
OnThree
OnThree
2015 mustang GT
Just in case anyone finds this when searching, that noise was indeed a bad bearing inside the trans.
Getting a partial rebuild right now, then I'll throw the trans back in and then it will be headed to the closest dealership for a trade in. The MT82 and clutches these cars get from Ford are a joke
Kong76
Turlock, Ca
2016 Ingot Silver GT
Yep clutches for the 15-17s are made in Turkey. I had mine replaced at 19k. I had them replace everything. Clutch, flywheel, pilot bearing and tob and it still has a vibration during clutch disengagement ( clutch to the floorboard) at 1500 rpms. I am just waiting for it to go again.
OnThree
OnThree
2015 mustang GT
I hear ya, my stock clutch went at 24k and then the trans at 40k. I'm not keeping the car to see what fails next lol. Next car will have a tremec though, that's all I know haha
Kong76
Turlock, Ca
Hell yea on that Tremec.
My transmission was replaced as well. Said faulty synchros. I dont beat on the car. If it wasnt paid off I would dump it.
mtabers
Ann Arbor, MI
Michael
2015 Mustang GT PP
Hey onthree just to clarify, this was a bad throw out bearing or?
OnThree
OnThree
2015 mustang GT
I'm about 90% sure it was transmission internals but can't say for sure as I replaced the throw out bearing at the same time.
Throw out bearings don't make any noise in netrual as they are not doing anything, they make noise when the pedal is pressed then you know the throw out bearing is bad. Mine only made noise when the clutch was not pressed. It was extremely loud when driving around and the car would vibrate at speed.
Good video below that may help
mtabers
Ann Arbor, MI
Michael
2015 Mustang GT PP
Yeah the noise I am having is very similar, I appreciate the info. How much did it cost for you to have done and what exactly was done to transmission internals? Or did you just take to a shop and they knew what was up?
OnThree
OnThree
2015 mustang GT
I had all the bearings replaced in the transmission, the input, output, and whatever else is in there. I pulled the trans myself and brought it to a guy. My throw out bearing only had 10k miles on it as I had replaced it before. I seriously doubt it was that.
It cost me about $800
mtabers
Ann Arbor, MI
Michael
2015 Mustang GT PP
Did you go OEM bearings or have any recommendations? I see on Ford parts website it lists the input, output, and counter shaft bearing - I haven't had a chance yet to research if any companies make good aftermarket ones for the stock MT82 but plan on doing exactly what you did plus new clutch/flywheel/pilot bearing. Just gotta get a trans jack from Harbor Freight and drop the trans myself. If you had any good info about the procedure that would be helpful too. I have see a few posts and videos from CJ pony parts that seem pretty helpful.
OnThree
OnThree
2015 mustang GT
Tbh, I'm not sure. I didn't really care what the shop did to it. I was fed up with the car and just wanted it gone by that point. I'm assuming they just used OEM stuff.
Pretty straight forward job, the only tough part is the top two bellhousing bolts. People say to get them from the bottom with a 3 foot extension and swivel socket but you're just asking to round off a bolt doing it like that. I ended up just pulling the intake manifold and then there's plenty of room to get those bolts. The rest of it's pretty straight forward.
NGOT8R
Adrian
2019 Bullitt
I know this is an old thread, but I’m curious to know if you pulled the dust covers on your bearings to have a look underneath? If so, what did the grease look like (thin, lack of grease or thick and intact)?
That_white_gt
Vista CA
Logan
1988 Mustang gt convertible(aod) 2018 mustang gt pp1 M6
Engaged does not mean your foot is pressing the clutch pedal
That_white_gt
Vista CA
Logan
What a disappointing thread. "Hey guys trans shop fixed my noise, it was definitely something in the transmission hope that helps" i feel so informed and like i learned so much about how to fix this issue.
