Injectors/BAP vs Fuel System Upgrade
Eric5899
Eric
2019 GT 401A
Is there a recommended rwhp level where upgraded injectors like ID1050x and boost a pump is adequate vs needing to also add a fuel system (pumps) and rails like the Fore? FI/E85. Thanks!
erikkire18
santa barabra,ca
5.0 Hellion TT
if you plan on boost get a fore fuel system if you plan on E85, skip the BAP. Get the id1050x injectors since you will most likely want more HP down the road. I bought a BAP and 2 weeks later went to E85 and got the fore fuel system. Depends on what your guna do as far as NA or boosted. You wont need a BAP if you get a fuel system. but if your NA than maybe just a BAP, the 1050x will be a bit much for that HP level. beefcake gave me a good price on my systrem
Eric5899
Eric5899
Eric
2019 GT 401A
I saw this note on the Fore page -
Tuners are still working out the integration into the OE electrical system.
Did your tuner have any trouble?
erikkire18
santa barabra,ca
5.0 Hellion TT
Nope none at all. I use Lund. Got the fuel system installed and got my E85 tune, did some dstalogging and was done.
ENPhoto
Hoonigan
Calgary, Alberta, Canada
www.ErikNymanPhotography.com
Erik
2016 Mustang Gt Premium Performance Pack
Shaun @ AED posted a video of a 16 with a single turbo a while ago.
Twin gt350 pumps. (Rodeheavers kit). No bap. Maxed at 9xxwhp.
Plugged in a boost a pump, aftermarket rails and hit 11xxwhp.
bluebeastsrt
Oh boy
New Jersey
BigD
Ruby red 2019 GT Premium.
How much power do you want to make? If you have plans to hover around 700whp. You can get away with a bap. You can buy kits on the cheap. That comes with bigger injectors.
beefcake
Bethel
2018 Ford Mustang
we always recommend a good quality fuel system like fore, we have systems that are very reasonable for what you get, 30-50k on a car, 6-12k in power adder, then how cheap can we go on fuel.
it's the most common thing i see, cars work off air and fuel, the 2 most important components.
and you won't find a better warranty or someone to stand behind their products than justin and the guys over there.
hit me up with any questions you have on fueling
Jay-rod427
Kansas
2016 GT C/S
Lund won't even tune boosted E85 on a BAP. If you ran like literally 6lbs you could maybe talk them into it. Just saying they don't trust bap's
NikNala
El Paso, TX
Sold-18 GT A10
It’s not that they don’t trust baps, just not for this application on E85 and boost. They tuned my pullied and ported 2014 GT500 on E85 with a KB Bap.
beefcake
Bethel
2018 Ford Mustang
the problem is, the 11-17 cars run a static 55psi f/p. with the baps, most people don't log, when you log a car on bap and e85 and boost, you'll see big f/p drops, the big injectors help maintain the a/f, but with the low f/p your just a small hickup away from a popped motor
