I broke two records today...
AMAlexLazarus
Malvern, PA
www.americanmuscle.com
Alex
'14 F150 EcoBoost/'08 Bullitt
What happened? And more importantly, how much is it gonna cost you?
I too was curious...And then I saw your last name!
:lol:
MultiMediaWill
MultiMediaWill
Naperville, IL
2016 GT Premium Magnetic
This thread delivers.
Mistake 1-Going to a machine wash (yikes!)
Mistake 2-Doing to a track driven machine wash (double yikes!, the new GT350 manual explicitly says don't do this, should have done the same with the GT)
Mistake 3-Riding the clutch while riding along said track
3 strikes and the mustang is out (of commission). Im guessing you simply glazed the clutch surface and it will be OK.
What do you mean by this? What is the other 'not OK' option that could have occurred?
krahooligan
sucks man.
also, double clutching order of operation goes something like - clutch in, out of gear, clutch out, rev engine, clutch in, gear in, clutch out - right?
why wouldn't rev match suffice? clutch in, downshift, rev engine, clutch out. less steps...
MultiMediaWill
MultiMediaWill
Naperville, IL
Does rev matching burn the clutch? Since you are revving with the clutch in, isn't that bad for the clutch?
Barrel
Hoonigan
Cars and Trucks
Clutch pedal depressed releases the friction surface - revving has no affect on the clutch in this state.
Quick rundown: [ame]
krahooligan
There is no reason to "double clutch" a 2015 Mustang.... :headbonk:
thanks. [MENTION=15263]BBB[/MENTION] trolls again haha
MultiMediaWill
MultiMediaWill
Naperville, IL
Quick rundown:
So could you give me a quick rundown on important things to avoid doing to the clutch? I'm just a bit confused what is good and what is bad for the clutch.
Barrel
Hoonigan
Cars and Trucks
You want to get in an out of the clutch operation quick-ish. Too quick and it's jerky at low speeds. It's a feel thing more than anything. Too long and you risk glazing the friction surface and ruining the clutch.
Things to avoid:
Riding the clutch pedal with your foot with no intention of changing a gear such as at highway speed. This light pressure on the pedal affects the mating of the clutch and flywheel and will degrade the clutch over time.
Revving the motor up and dumping the clutch. The stock clutch is not suitable for this abuse and will fail prematurely.
Beyond that, the clutch is pretty stout and IMO is a good clutch to learn on. But when you're just idling away at a traffic light or a car wash, shift into N and release the clutch pedal.
kz
West Chester, OH
Mustangs & F150
I already did.
You want either disengaged (pedal in) or fully engaged (pedal out) and minimize anything in between (which obviously is necessary for smooth gear changes / start from 0 speed) as much as you can. There's no more magic to it, it's just pure logic with a bit of basic mechanical knowledge.
MultiMediaWill
MultiMediaWill
Naperville, IL
Things to avoid:
So avoid launch control?
MultiMediaWill
MultiMediaWill
Naperville, IL
I already did.
Okay thank you! So I'm assuming engaging the clutch halfway also with the brake pressed down is bad? I was doing this to avoid embarrassing stalls at red lights.
Earth
2015 DIB Coyote
Don't remember the last time I've gone to a car wash, always better to hand wash it. Hopefully your tranny isn't too damaged.
krahooligan
clutch should either be all the in or all the out.
Lowrider
Drive Fast...Live Slow
Driver's Seat
A poorman's coupe
In some situations the clutch cannot be all out. Eg when going up on a hill with tight bumper to bumper traffic...You will have to learn how to balance the car with just the clutch and the gas with no brakes...
In fact you can practice that on your driveway or uphill with no traffic. Get the car to the balance point where it is not moving with no brakes but just the clutch and gas...rolling it back en forth till you master that technic. And you can do it without burning the clutch.
