How to - OPG Replacment
Tomster
Beware of idiots
Tom
nastang87xx
San Diego, CA
2016 GT350 Track Pack
I just snapped in and made sure it moved freely. Used a little oil to lube it as well. Only hard part was accessing the rearward most screw that holds the oil pickup tube. That was on the GT coyote motor though. Not sure if the pickup is differant on the voodoo motor. I had heard that it is in some way and the oil pan had to be dropped. On the GT I did not take off the oil pan. check post #329 in link below.
http://www.mustang6g.com/forums/showthread.php?t=33032&page=22
Noice. Good work.
JCSIX13
JCSIX13
MA
Jack
2016 GT350
It looks like a other how to/review post tob...... up for it?
Originally Posted by Epiphany View Post
Voodoo pickup is integral with the pan.
What he said! Epiphany you write great how to / reviews!
Victor-Delta 4-2
Mexican Food Mercenary
Co
www.adp-photo works.com
2017 GT350
You have to drop the pan to get the oil pump out. Pick up is attached to the pan and it slides over the oil pump. No two bolt flange like the GT has. To drop the pan you should raise the engine. If you don’t want to raise the engine, it can still be done by removing the oil pan bolts and dropping it the inch or so you have to work with. However cleaning up the old silicone off of the pan with only a couple inches to play with is frustrating.
It’s a PITA on this car vs a GT.
Zombo
befejezett
2016 GT350 Track Pack - Race Red, Blk Roof - G5405
I'm surprised a sealant is used at the oil pan interface. The composite pan assembly includes an integral molded o-ring like gasket. I wouldn't think an additional sealant would be required? Interesting.
Victor-Delta 4-2
Co
2017 GT350
It only has sealant in 4 places. Where the block meets the rear main on both sides and where it meets the front cover. So at least you don’t have to scrape the whole pan. But those 4 spots aren’t super easy to get to.
Epiphany
Global
I like to disassemble things.
Were I adding a blower to this car I'd take this one on. I'm not here to light the fuse on this one but for me, I'm good with Ford's "factor of safety" with respect to the stock gears/sprockets. That is not to say that I don't like the aftermarket pieces - I do.
Epiphany
Global
FR now sells a GT350 5.2 engine oil pump with steel gears. That price though...
FR said:
This billet steel gerotor oil pump is designed specifically for 5.2L Mustang GT350 engines
Fits: 2015-2017 Mustang GT350 5.2L
  • Oil pump assembly with billet steel gerotor set
  • Produced by OEM manufacturer to minimum allowable tolerances
  • Pump assembly is pressure and flow tested with OEM procedure
  • Recommended for race applications
https://performanceparts.ford.com/part/M-6600-M52
Tank
9/11 - Never Forget
Above the Notches
G0853
Tank
9/11 - Never Forget
Above the Notches
G0853
Apologies on the possible :threadjacked:....
Spoke w Mike at ANWBL, part M-6600-M52 expected ship date is 12/29/17. Cost to us $602.80. This is about the same price as the coyote billet oil pump. Mike states price could be lower w enough interest...he’s not really interested in a group buy at this time.
Back to original programming...
Dominator
MIT
GT350
You "MUST" raise or pull the engine or drop the K member to swap the oil pump / gears on the GT350/5.2
Victor-Delta 4-2
Co
2017 GT350
Trust me. You must pull - lift or drop the k member. The 5.2 does not have a bolt on pick up tube it's part of the pan.
Trust me, I know. And still, it’s not required to lift the engine or drop the K member. The 1.5” clearance given is enough to get the pump out.
Dominator
MIT
GT350
Look. Explain to me where your getting the 1.5" of clearance?
Their is none! You only have 5/8-3/4" of oil pan to k member clearance. This is NOT like the 5.0.
It is impossible to pull the oil pump off the crank snout without dropping the oil pan because the pick up tube is apart of the pan itself.
Don't try telling me you can do this without dropping the oil pan.
