How low is too low??
Chargersfan81
Chargersfan81
2016 GT Race Red
No such thing as too low!
WOW!!! LOL you're car is nutz man! It is a bit too low for me but as long as you like it, that's what matters :cheers:
The wing makes it look crazy aggressive.
Chargersfan81
Chargersfan81
2016 GT Race Red
It can handle a little more than 1" fine. I run the Sportlines and they are great.
That is pretty good.. I bet you can fit maybe two fingers between the fender and the gap.
But having that small gap makes it look very sporty.. I'm trying to go for that look as well. I may use pro-kits from Eibach since it's about an inch drop.
Chargersfan81
Chargersfan81
2016 GT Race Red
More than 1" drop is too much on this car. It upsets the suspension geometry, reduces street usability and creates an ugly non-concentric look between the wheel arch and the wheel, where the gap on the sides/bottom is wayyyyy bigger than the top.
If you like to ruin most of the good things about a performance car, drop it 1.5+" :thumbsup:
Agreed!
Todd15Fastback
Atlanta, GA
Todd
2015 Mustang GT PP Fastback
Wow, good to know you can go that low with 20's and have no rubbing issues!
Yep. The ultralite linears have about 1.12-1.25" inch drop at each corner.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
[MENTION=15475]daltron[/MENTION] that looks on the high side compared to a lot of Sportline setups I've seen (a good thing).
I worry about how much the front-to-rear roll coupling changes when you drop it more than a little bit, as they won't lower the roll centers equally. I also care about being able to use the car every day and not freak out over parking curbs and speed bumps, in addition to the performance.
Ideally I'd get something with ~0.5" drop and stiffer spring rates all around. It's enough to lower the CG to without getting outside the geometry's optimum working range, and looks better.
I hope I don't see a stanced S550 around me, I might be sick. That's gotta be the worst/dumbest car trend I've ever seen.
wireeater
Virginia
wheelwell.com
Rich
Shadow Black 2025 Mustang DH HP
For visuals I think the first one looks perfect for stance. I can't stand large amounts of wheel cap on a sports car. However the second picture is more functional with less risk of scraping, and rubbing.
Just be happy it isn't cambered.
daltron
Rowing All Day
Jonathan
2016 GT PP
@daltron that looks on the high side compared to a lot of Sportline setups I've seen (a good thing).
295/30/19 tires, too. I'd imagine 35 profile or 20's would look considerably more compact.
It's a little tough sometimes, I'll admit. While the 30/19's look good (IMO), the car is very low to the ground. My Steeda K-member is slightly less than the height of a GoPro from the ground (Yes, I knocked one over when I drove over it lol).
BmacIL
Enginerd
Naperville, IL
Ah that makes sense! The reduced sidewall height makes it look less slammed for sure, but it does look very good. I was going to guess around 1" or maybe a touch less drop if you hadn't said Sportlines. You're probably at almost -2" ground clearance from stock with that setup...definitely reduced daily utility. I also drive mine in winter, so that would be a total no-go.
Todd15Fastback
Atlanta, GA
Todd
Supa LA
Drop a gear and disappear
So. Indiana
2015 Guard Metallic Mustang GT PP
Flush is the best fitment, on any car. A small amount of tire tuck looks good on some cars, but makes maneuvering the car around obstacles tricky. My last two sports cars were slammed with coilovers. 2" or less of ground clearance, and that gets old and stressful in every day driving. I am going with the new Steeda springs once (if ever) they are released. They give the car about a 2" drop all around.
Oko3612
Delray Beach, FL
Magnetic PP 15 GT
Lowered about an inch on steeda ultralites. Absolutely love the drop. No rubbing or issues for daily driving:headbang:
CompO5.sl0w
GTFO_0021
Martinsburg, WV
Trevor
2016 Mustang GT/PP / 2015 Jeep Rubicon
Love it lol. The less gap the better IMO. To each his own.
Ender
Phoenix, AZ
2016 B5 Blue Challenger Scat Pack
I also don't get the obsession with hiding tires under the fender. It tends to look bad, decreases performance, and makes every bump/hill a tribulation; it's not worth it. Just seems like a ricer thing that got passed on to Mustangs for some reason.
I can understand a minimal drop. For example, I think daltron's car looks great. Any lower than that and it would just look off.
daltron
Rowing All Day
Jonathan
2016 GT PP
[MENTION=16053]ven377[/MENTION], is that the AD rear valance? Looks sick!
Thanks!
