engineermike
I’m pretty sure ford says to replace the head bolts, cam tower bolts, phaser bolts, and maybe more due to the torque-to-yield design. I’m not sure about the oil pump bolts and front cover.Which bolts?
ARP cam tower bolts, ARP head studs, New FRPP cam phasers and hardware, as well as new oil pump hardware. The guy who was helping me today is a very good Ford tech with over 20 years experience. I brought up the TTY issue about the cam phaser bolts and he said it's not an issue.I’m pretty sure ford says to replace the head bolts, cam tower bolts, phaser bolts, and maybe more due to the torque-to-yield design. I’m not sure about the oil pump bolts and front cover.
Make sure you have the latest revision of the directions. Lay everything you are working on, out on a table so you can see what you are working with. If something doesn't seem right, email Whipples tech support. They are very good actually.How did you guys do on your installs were Whiiples directions sufficient for the installation?. All help appreciated.
I will, Thanks.Make sure you have the latest revision of the directions. Lay everything you are working on, out on a table so you can see what you are working with. If something doesn't seem right, email Whipples tech support. They are very good actually.
Come here and ask questions or DM me.I will, Thanks.
Thank you.Come here and ask questions or DM me.
I was swapping over to ID1050s and I am having this same issue with my Whipple. The rails won’t bolt back up. I looked for your update on how you got the 1050s to work but I didn’t see it. Could you let me know what you ended up doing to get the rails bolted back up and with what spacers?I tried removing the spacers provided on the 1050's but that ended up being almost as short as it was too long with them on. I started a support ticket with Whipple to get some answers on the spacing. I will update when it happens. In the meantime I got the front accessory pulleys worked out ( I believe), so all that is mounted. Part of the issue on the pulleys is the spacers. They have 4 pulleys of 5 that use step spacers. 2 use one sized .390 inches and 2 use one sized .317 inches. They look very very similar, and only 1 of the 4 came in a bag that actually had the size marked on it.
I think I am going to move forward with plumbing as much of the heat exchanger plumbing and mounting as I can without it being in the way of doing the rest of the installation once I get the injectors/fuel rails situation worked out. Tomorrow, I'll take and post some pictures so that it's here for the next guy.
I was just told you have to use the "thinner" O Ring seals, and not the larger, thicker ones. Keep us postedI was swapping over to ID1050s and I am having this same issue with my Whipple. The rails won’t bolt back up. I looked for your update on how you got the 1050s to work but I didn’t see it. Could you let me know what you ended up doing to get the rails bolted back up and with what spacers?
Thank you, yes, I did swap over to the thinner O-rings. I know there are two bolting locations on the side of the whipple, one upper and one lower. I did go ahead and try to bolt them up to the top location last night. It does look like it is correct. When I first aligned it, I knew it wasn’t going fit on the lower location but the top one made it look like the Injector wouldn’t seat correctly. Now that I’ve installed it I think it is correct.I was just told you have to use the "thinner" O Ring seals, and not the larger, thicker ones. Keep us posted
This is what Whipple told meThank you, yes, I did swap over to the thinner O-rings. I know there are two bolting locations on the side of the whipple, one upper and one lower. I did go ahead and try to bolt them up to the top location last night. It does look like it is correct. When I first aligned it, I knew it wasn’t going fit on the lower location but the top one made it look like the Injector wouldn’t seat correctly. Now that I’ve installed it I think it is correct.
I did send a support ticket to whipple just to try and verify that this is correct. I also wasn’t sure if I should remove the metal spacer (pictured) that Whipple supplied before installing these injectors. Once I get confirmation, I will update this post.
