2wheels4me
I highly recommended the Steedas, especially in comjunction with their linear springs and other suspension improvements (see signature below) that I have on my GTPP. Vastly improved handling.
I know Steeda has always been blue. I wish they would come in red. I'm an aesthetics kinda of guy. I'm a big fan of Steeda which is why I'm going to end up with blue parts on my Race Red GT. :headbonk:My 2 choices were between Steeda and BMR only.
I ended up going with Steeda for their sway bars and billet mounts. The quality is amazing. The front has 4 adjustments and the rear has 3. I just took my car to the Tail of the Dragon (381 turns in 11 miles) and the car was amazing in the turns. I could easily run up on stock GTPP cars in turns, the turn-in is very precise, very flat cornering and brake dive is essentially gone. I cannot recommend their components enough. David is great to work with. Ask him all the questions you want.
Here are a few pictures:
LOL! The blue looks good on my Ingot car . We can call you Richard Petty Jr. with the red and blueI know Steeda has always been blue. I wish they would come in red. I'm an aesthetics kinda of guy. I'm a big fan of Steeda which is why I'm going to end up with blue parts on my Race Red GT. :headbonk:
You sound like a Whiteline rep. :headbonk:Personally, I am more of a "soft spring, big bar" kinda guy.
Everyone has their preferences, that is just mine.You sound like a Whiteline rep. :headbonk:
lol +1Everyone has their preferences, that is just mine.
Don't get me wrong, using an eleven-million lb/in spring is cool and all, but no thanks.
If I wanted a pure racecar (which I prefer big spring rates), I'd build it from the ground up, not go sign papers on a new one.
Very good info.Happy to outline some key benefits of the Steeda sway bar kit. Our sway bars have machined steel billet sway bar ends, whereas others on the market have coined ends. What does this mean?
Our sway bar ends are machined out of billet steel round stock, in-house, on our multi-axis CNC lathes and go through hundreds of computer simulations to ensure the ultimate in strength and performance - this provides greater resistance to bending stresses, and has three major advantages:
- 1. These parts are less prone to cracking/fatigue failure on the ends themselves.
- 2. It also reduces unwanted deflection in the sway bar end. Excess deflection creates unwanted geometry changes, which physically changes your sway bar stiffness to a non-ideal rate. Unwanted deflection also slows down the response of the bar/suspension system in general as you have to wait for the part to deflect before it reaches its steady state spring rate for the respective maneuver. We put enough gap between the sway bar and the sway bar mount so under severe cornering it doesn’t put an artificial spring rate or bind into the suspension.
- 3. With less unwanted deflection, our bars will 'wear out’ slower - any spring will eventually become softer over time as it is cycled through its life, our bars will maintain their designed rate for longer with less unwanted deflection.
Welded sway bar ends are also less prone to failure around the welded area, coined sway bar ends create high-stress concentrations around the area where the tubes are crimped, therefore can fail under extreme conditions. In this area, the wall thickness of the tubes are actually thinner as they are stretched to make the bend - we view this as a weak link in the chain.
We provide very nice Grade 10.9 Allen Head Bolts for our front sway bar mounting, simply because the Billet Aluminum Mounts (that come standard with our kit) are too nice for the OEM Bolts. Actually, that is part of the reason - but the other reasons are due to the ease of damaging the threads on the front mounting bolts when R&R them, and the fact we design our Billet Saddles for Allen Head Bolts.Our bars don’t include any, what we believe to be ‘unnecessary' hardware. With the welded stops we provide on our bar, there’s no worry about any chances for improper installation by our customers. There is also no need for the customer to worry about any billet hardware (included in some other kits) to come loose overtime.
Our parts have all their tolerances tightly controlled in-house, and all parts are thoroughly quality-inspected. This eliminates the possibility of receiving defective parts from the factory if you’re using a third-party supplier.
Same here, great companies think alike.Lastly, our bar rates are developed and optimized through advanced vehicle dynamic simulation and through extensive real-world testing. We engineered these bars to control the vehicles' roll stiffness properly while still allowing you to run softer springs. This optimizes your overall grip and balance of the vehicle while still allowing you to maintain exceptional ride quality.
We have exceeded the strength of the OEM Links on our test cars, and also have several customer who have as well.Having custom end links is a great addition to this package and we have some on the way, however our bars work with the stock end links in every form which allows you to take home the same performance without the need to swap the end links as well. I’m sure BMR’s end links work great in the meantime, though.
We have never had a failure with our Hollow Mustang Sway Bars that have coined ends.Most importantly, we have never seen our sway bar billet ends fail, yet we have seen coined ends fail. Also, aftermarket bars are much stiffer than OE, so why would you want an OE-style coined end when a billet end is stronger and better suited for the beefier bar?
Can't remember sizes, but front FRPP bar is hollow and the rear bar is solid.So I am searching for a thread the compares the material and size of the sway bars.
The PP ones are solid ? what size.
The Same for Steeda and BMR?
thanks
as a fellow previous s2000 owner, my goal is to get the stang to carve the corners like that little thing did!How big of a difference do these make to handling feel compared to GT PP sways?
Coming from a highly modded S2000 of course the tightness and handling of this car feels sloppy and heavy. I'm looking to reduce body roll. Even pp has a good amount it seems. Especially from the rear.
