How do I disable alarm button on key fob?
clevernickname
BC, Canada
2015 Magnetic Mustang GT, 2016 camaro ss (gfs), 2015 range rover sport, 2013 ford explorer, 2017 WRX
Can't find anything on google. 2015 mustang gt if it matters. base model.
BMAGOO
Alberta, Canada
2016 Mustang GT/CS, 2016 Explorer Sport, 2015 Ram 1500 Sport, 1968 Firebird
I’ve seen something on here before about guys opening up the fob and putting a small washer or something under the button to prevent it from being pressed. Also a possibility you can do something with forscan to disable it, not sure. Try using the search function on this forum, should find something.
Tobey
16 Vert
I used to accidentally set off the alarm at least once a week with the keys in my pocket. If you take the fob apart, there's a rubber nub the button presses on which then pushes the actual button. I cut the rubber nub off. Haven't accidentally set off the alarm since.
