How bad it’s really going wot all the time?
Discussion in 'Forced Induction - 5.0L V8 Engine' started by SSG 5.0, Nov 3, 2019.
  1. SSG 5.0
    SSG 5.0 Well-Known Member
    Vehicle(s):
    2017 Mustang GT
    Mar 11, 2019
    531
    98
    0   0   0
    Good evening y’all. Well it has been a few months now with the Procharger P-1X. The car is absolutely amazing, although I hardly drive the car. Every time I get the chance to drive it, probably no more than 5 miles a day, I absolutely go wot when I have the chance. I do wait for the car to get the right temp before I do go wot. The car seems fine and I’m just wondering if I’m hurting the car because I hardly drive it and go wot when I drive it. Thanks.
  2. 80FoxCoupe
    80FoxCoupe Well-Known Member
    Vehicle(s):
    16 GT, 80 Fox
    Mar 28, 2018
    Cincy, OH
    1,382
    765
    Rating:
    100%
    5   0   0
    Really?
    turnswrench likes this.
  3. 3star2nr
    3star2nr Well-Known Member
    First Name:
    Ray
    Vehicle(s):
    2016 Ford Mustang GT PP
    Aug 25, 2019
    31405
    811
    548
    0   0   0
    Its A reasonable question even professional racing schools talk about not going fully WOT to lower wear and tear on the engines.
    For competative driving they don't give a shit, just survive the race.
    That said OP. the coyote is a very strong motor, its not as delicate as some on here would have you believe, so enjoy ypur car.
    Just make sure to monitor your oil temps not your coolant temps... The oil is the most important thing, if u start reving high and dping WOT on cold oil you're just punishing your main bearings.
    On These motors the things to be wary of is the ringlands mainly due to detonation , bad fuel and high boost levels. The oil pump and crank gears and of course the stock clutch...
    Ford Claims These cars are designed to run on 87 octane... But i recommend getting 93 only... Its cheap insurance
    SSG 5.0 likes this.
  4. OP
    SSG 5.0
    Vehicle(s):
    2017 Mustang GT
    Mar 11, 2019
    531
    98
    0   0   0
    Thanks for the input man. I do monitor almost everything after installing the s/c. I don’t go stupid after starting the car because the oil haven’t lubricate the entire engine. I’m mainly using top gas company for 93 fuel because it is tune for that octane. The car seems healthy even beating on it every time I get the chance to drive it. Big investment for so I got to ask experienced mustang enthusiasts. Thanks again.
  5. OP
    SSG 5.0
    Vehicle(s):
    2017 Mustang GT
    Mar 11, 2019
    531
    98
    0   0   0
    This car haven’t tasted an 87 octane since buying it brand new. I just never did went that route bec I know 93 octane is better than 87. Now it’s s/c, 93 is a must every time.
  6. BlackandBlue
    BlackandBlue Well-Known Member
    First Name:
    Jay
    Vehicle(s):
    2018 GT 10 Gear
    Jun 27, 2019
    Southeast
    1,019
    640
    0   0   0
    As long as you are not getting knock you are fine.
    If you don’t drive it a lot drop some boostane in it to make sure you stay safe on octane.
    As for you question if you can be to hard on the car, I think the answer is no. As long as fluids are in proper range you are good. If there is something wrong with the engine you will find it faster but that’s just time either way. Keep knock in check, keep it cool and drive it like you want.
    Zinc03svt and SSG 5.0 like this.
  7. 3star2nr
    First Name:
    Ray
    Vehicle(s):
    Aug 25, 2019
    31405
    811
    548
    0   0   0
    it may not be a bad idea to do a compression test every now and then just to catch any potential issues early.
    These cars can crack a ringland and still run "healthy" until it melts the piston. If you catch the issue early u can salvage the engine.
    SSG 5.0 likes this.
  8. OP
    SSG 5.0
    Vehicle(s):
    2017 Mustang GT
    Mar 11, 2019
    531
    98
    0   0   0
    I guess boostane is a good insurance for this car. Yeah I’m keeping it cool, always monitoring the gauges, and no known knocks whatsoever.
  9. OP
    SSG 5.0
    Vehicle(s):
    2017 Mustang GT
    Mar 11, 2019
    531
    98
    0   0   0
    That’s a pretty good idea and testing the compression on this car never crossed my mind. Thanks man.
  10. 3star2nr
    First Name:
    Ray
    Vehicle(s):
    Aug 25, 2019
    31405
    811
    548
    0   0   0
    #10 3star2nr, Nov 4, 2019
    Yeah once a year is plenty. And its a easy do it yourself job. Gives you a chance to read the plugs too.
  11. 3star2nr
    First Name:
    Ray
    Vehicle(s):
    Aug 25, 2019
    31405
    811
    548
    0   0   0
    I'm personally wary of octane boosters because even though they are marked as O2 safe ive had sensors fail on an old car I used to run. These cars have wideband o2 sensors those aren't cheap to replace..
    I guess if you aren't going overboard with it you'll be fine. The good thing about boostane is it keeps the fuel stable when the car sits.
  12. OP
    SSG 5.0
    Vehicle(s):
    2017 Mustang GT
    Mar 11, 2019
    531
    98
    0   0   0
    I guess I should elaborate more on the car sitting all the time. Basically it’s a weekend warrior car. If not getting driven after 5 days, I crank the car and let it run so the fuel and engine oil cycles until normal temp is reached.
  13. 3star2nr
    First Name:
    Ray
    Vehicle(s):
    Aug 25, 2019
    31405
    811
    548
    0   0   0
    Yeah you'll be fine then... Itsjusta6 on YouTube ran 900+whp on a gen 2 for over a year heavy drag racing finally cracked a ring land... These engines are tough
    SSG 5.0 likes this.
  14. BlackandBlue
    First Name:
    Jay
    Vehicle(s):
    2018 GT 10 Gear
    Jun 27, 2019
    Southeast
    1,019
    640
    0   0   0
    I am not really a fan of boostane either but knock and heat is what kills these engines. If you are not getting knock don’t worry about it. I personally would use it on super hot summer months as cheap insurance. It doesn’t take much to get a couple of octane points.
    Didn’t touch on this the other day but I wouldn’t do pulls longer than 1/4 mile either. The rings gaping is tight on these cars and like said above expanding rings will kill ringlands.
    Sounds like you are doing everything right though.
    SSG 5.0 likes this.
  15. SolarFlare
    SolarFlare Well-Known Member
    Vehicle(s):
    2015 CO GT
    Aug 24, 2015
    S. Fla
    2,729
    929
    Rating:
    100%
    2   0   0
    Just enjoy it and maintain it. Wanna be safe? don’t enjoy it, simple.
Loading...
Share This Page
