Help with wheel fitment on mach 1
bobloblaw jr.
Indiana
Bharath
Ford Mustang Mach 1 2022
Looking for some winter wheels and found some used s197 mustang track pack wheels on facebook. Front and back 19x9. Hard to be sure on wheel offset but based on random websites looks to be +42mm.
Would these wheels fit and clear the brembo brakes?
Also does anyone know what the wheel offset for the stock (non-hp) wheels is on the mach 1? Any other tips to make sure fit is correct would be helpful as well, this is my first time buying a set of wheels.
Thank you!
Skye
≈39N
"Skye" Mach1 N2144
I can't say if what you've bought will clear the Brembos.
Here are specs on wheels I've gathered from threads and Order Guides:
GT500 CFTP wheels are +32 front, +50 rear, 305/30/20, 315/30/20, 20x11, 20x11.5.
GT500 Base wheels are +32 front, +50 rear, 305/30/20, 315/30/20, 20x11, 20x11.
GT350R wheels are +24 front, +56 rear, 305/30/19, 315/30/19, 19x11, 19x11.5.
GT350 wheels are +30 front, +62 rear, 295/35/19 and 305/35/19, 19x10.5, 19x11.
Mach HP wheels are +24 front, +52 rear, 305/30/19 and 315/30/19, 19x10.5, 19x11.
Mach non-HP wheels are +40 front, +52.5 rear, 255/40/19, 275/40/19, 19x9.5, 19x10.
GT/PP2 wheels are +24 front, +48 rear, 305/30/19, square, 19x10.5, 19x11.
GT/PP1 wheels are +45 front, +52.5 rear, 255/40/19, 275/40/19, 19x9, 19x9.5.
GT/CS rims appear to be 8.5" square, 255s all-around. Offset To Be Confirmed.
bobloblaw jr.
Indiana
Bharath
Are the wheels listed about all known to work with the mach 1 or these are jus the sizes you have gathered?
Thanks for the help.
bobloblaw jr.
Indiana
Bharath
Also anybody have issues with 9 inch diameter wheels in general? I have lead on a set of 20x9 wheels as well.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Most 19” wheels will fit and the offset is fine but its not gonna win any trophies for most caffinated fitment at your local cars and coffee, but it will work.
9” probably ok. Does snow want wider tires but cold rain narrower?
I Bleed Ford Blue
North East OHIO
https://autorimshop.com/products/20...267&gbraid=0AAAAADmwUKadIc47pkP50CR0X77SKv2H8
Is this the wheel? A few years back someone put them on a PP1 for winter tires and they clear the PP1 brakes. Mach 1's use the same brakes as a PP1. Just make sure they are original ford wheels, not the american muscles clones, they don't clear the big brakes of the PP1. Like I said, the real ford wheels do clear, the knock offs don't.
Skye
≈39N
"Skye" Mach1 N2144
They are sizes I have gathered.
You might use the Mach-specific ( looks like PP1 to ) measurements to compare against what you bought.
