Help with headers
BrazukaV8
Los Angeles CA
Carlo
Mustang gt PP
What's up guys. Need a quick help. I'm about to order some stainless power long tube headers off road. And was wondering which one should I get. I currently have corsa extreme cat back. Should I get performance connect or factory connect. I want something that I can bolt on and off from the cat back. Not weld. Cuz I know I will probably trade my extremes for either the sports or something more quieter. Thanks in advance.
Niz55
Us
17 GT350
Sell your extremes and go full ARH setup. Sound killer also.
MyLilPony
Naw It's Stock
Prosper, TX
Kris
2015 Black GT, 18 JLUR, 15 JK
Get the factory connect then. The performance connect is only good for true 3 in systems which you do not have. It doesn't sound like you will be going that route immediately either.
daniel_94kg
North Carolina
2015 Ford Mustang 5.0
I just went with the factory connect on my car. Works perfectly fine.
Wally
St. Petersburg, FL
2017 Challenger Scat Pack
Not sure which connect to recommend but if you are just going from extreme to sport, you are only changing the mufflers. X pipe is the same.
Swayse
2015 gt auto
I'm guessing performance connect will be 3" all the way. I did that with my ARH headers, fit perfect.
beefcake
Bethel
2018 Ford Mustang
you can do the factory connect that has the 2.25" neckdown connection
or,
we have our exclusive design that has the exteneded leads that are cut to fit, you can pull the neckdown insert out of the corsa, and trim our leads to fit inside, giving you a single full 3" connection
this is an exclusive setup we worked with stainless works to go with the corsa and other 3" systems
they are the "xl" version
http://teambeefcakeracing.com/stainless-power-headers-mustang-2015-17.html
Vanquisher
US
15 Mustang GT
ARH also has the direct connect for corsa systems. I run it works nice.
Taneras
Ascension Parish, LA
2015 Auto 3.55 GT
SP O/R headers + Corsa Extreme is crazy loud. It's right at the cusp of what I find tolerable but it does sound pretty sick. I get a lot of head turns and compliments as I drive around.
Idle sounds pretty good too. You'll like it!
