HELP WITH CLUTCH NOISE
DriedAir
Brainerd, MN
2016 Mustang Gt pp1
The higher pitch noise is when the clutch is just barely pushed in and the more rough metal(ish) noise is after I push it in more. This is my first time doing a clutch. If you guys have some info please let me know.
LCK22GT
Michigan
Larry
2022 Mustang GT / 2021 F150
I got a warning message on your link, so I didn’t open it. It sounds like a worn throw out bearing from your description.
DriedAir
DriedAir
Brainerd, MN
2016 Mustang Gt pp1
Should be able to view it now. I just replaced the throw out bearing. I might not have bled it all the way.
LCK22GT
Michigan
Larry
Some more experienced clutch repair guys here can give you tips on adjustments.
I found this video on noise with light pressure
Zrussian13
Phoenix
What type of clutch and tob did you install? It definitely sounds like a tob issue.
DriedAir
DriedAir
Brainerd, MN
2016 Mustang Gt pp1
It's an oem tob and I did a vengeance stage 2. 23 spline. I have a mcleod line with a bleeder on the way now. I'll throw that in when I get it.
Zrussian13
Phoenix
Did you buy an oem tob for a 15-17 or a 18+? If you put a twin disc vengeance clutch in i believe you need to use the 18+ tob.
DriedAir
DriedAir
Brainerd, MN
2016 Mustang Gt pp1
That makes sense since the 18+ are twin disk from factory. That didn't cross my mind I'm gonna probably buy an 18+ one then if the bleeder line don't do anything.
