Sooner 5.0
It's lowered 1 inch all around. I just bought the Steeda subframe alignment kit. Going to do that then have it aligned again. I think that'll take care of it, hopefully!Have you lowered the car? if yes was the subframe put back up properly if yes, then check your camber if its at 0 thats your issue right there.
The GT PP comes -1.5 factory for every 1" you lower you theoretically gain -.5 degrees of camber so your car should be at -2 degrees and then youll be good.
