Help! Pypes X pipe install
NEED2015GT
Illinois
15 GT base PP Borla s-type H pipe
I have a 19 GT with the heat shields on the exhaust. I have a pypes x pipe that I’m trying to install. The problem is they want you to remove the heat shields. I was thinking of cutting the x pipe and the factory pipe to fit with the heat shields still there. Has anyone else done this.
EPTS550
El Paso Tx
Jerry
2019 GT
Yes. Cut the heat shields. If for some reason you don't wanna do that, then you can try and shorten the pypes a little bit. As long as the overall length is there you'll be fine. Not sure if you have enough length on the slip joint if it's cut.
In all honesty, just cut the shields.
Mikepol2
Pittsburgh, PA
2021 Mach 1, 2019 Ram 1500
I've had an MBRP X-pipe, a Steeda H-pipe, and a Magnaflow resonated X-pipe, and none of those three were designed in a way that the shields needed to be cut. I'd see if there's a way to modify the X-pipe before modifying the stock exhaust.
sabtaj1
Bettendorf, IA
Jason
2019 PP1 Mustang GT, 1965 Fairlane 500 wagon
It’s probably designed for the 15-17. Cause Steeda makes a specific for the 18-19 to where the cut is before the heat shields.
NEED2015GT
NEED2015GT
Illinois
I was about to cut the x pipe a 1” off the front was able to keep the heat shields. This also saved a lot of work getting them welds down from the heat shields. Hope this helps someone in the future.
NEED2015GT
NEED2015GT
Illinois
this makes sense since my 15 GT didn’t have any heat shields on the stock system.
