SteveW
- Jun 3, 2015
- Columbia Gorge area
- 2015 Mustang GT PP
I agree with this. You can't go wrong by adding this bracing. @SDAMike Do this next then go from there.Until you put performance pack bracing it will drive like a wet noodle no matter what you do with tires.
I don't think the rest of your setup is out of whack for a street car but may need fine tuning like:
Lower tire pressures from 40 to what others have recommended.
Reset the shocks to full soft and adjust one end of the car at a time until you feel it getting bouncy or springy then back off a 1/4 turn. If you continue going stiffer the ride will get harsh and you may lose traction completely over bumps while turning. Adjusting one end of the car at a time will help you feel more clearly what the changes do to your ride and handling. Also, the front shock settings will likely be different from works for the rear.
Alignment could be contributing to poor handling but if you really have it set to BMR's settings that should be ok.
