Help line lock
BonGT
Odessa Texas
Esteban
2019 Mustang GT PP1
I have a 2019 mustang GT base PP1. I have tried using the line lock but ran into a issue. I make sure the car steering wheel is straight and that I am on a flat level surface. Below are the steps I have taken to engage it.
1. turn off traction control.
2. Go to track apps and click on the line lock setting.
3. Mash on the brake until all the bars come up and it gives me the countdown.
As soon as I press ok to begin it immediately tells me to go over the manual. I purchased the vehicle used without the manual. I recently noticed my driver side wheel has a malfunctioning sensor. Could the be the cause for it not working? Thanks for your help I went off the steps on the ford website too.
ChromaticGrey
Nevada
Grey
2017 Mustang GT PP1
Don't let your foot back even a millimeter on the brake pedal before clicking ok, that has gotten me a few times.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
A bad ABS sensor could definitely cause issues with line lock, id get that fixed asap because it also causes advance trac issues
Elp_jc
None
I'll probably never use that feature, but out of curiosity, once it's engaged, do you need to keep the left foot on the brake or not? Just curious. Hope nobody tried that crap on my car when it was test-driven. Ha ha.
Mustang5ohMan
A
2019 Mustang GT PP1
no. Line lock, locks the brakes. It’s a show trick or if you actually track your car
Elp_jc
None
Yeah, I know. But my question was how do you release it once engaged? Read the manual, but not much detail after pressing the 'ok' button, for what I remember.
I Bleed Ford Blue
North East OHIO
I used mine once just to try it, once engaged, you have to keep holding the OK button. When you release the button it disengages.
FatPat
Chicago, IL
2015 GT
Once engaged it's on a timer, I think 10 or 15 seconds. It will automatically disengage after that. Or you can press the ok button at any time to disengage, this can be done while tires are spinning, so be careful.
Mustang5ohMan
A
2019 Mustang GT PP1
then you wouldn’t have to hold the ok button...?
brucelinc
MN
Bruce
2018 Mustang GT premium A10 (SOLD)
I use mine at the strip with zero issue but never hold the OK button like you say. Press it engage and once done with the burn out, press it to release.
brucelinc
MN
Bruce
tried to roll out of it before?
Not sure what you mean. It is on a 15 second timer but I never do my burnout that long. I hit the OK to release it in the water but keep spinning until I am on dry track so the tires are 100% dry and hot.
