Thank you! I’m doing that tomorrow. I watched a couple videos where they did things differently so I got confused lolPlenty of you tube videos. When I changed my steering wheel I disconnect both positive and negative battery terminals. Waited 30 minutes with doors unlocked.then I removed, old steering wheel, then installed my new steering wheel. Watch videos. Good luck
You Must Depower the SRS Syetem, remove the RCM Fuse, then Deplete all Power residue by disconnecting the negative battery terminal and then wait for 20 or more minutes. I always disconnect both + and - and wait at least an hour before I put my Face in front of an Airbag to remove it,I don't want to add to the confusion, but the procedure in the factory shop manual says that if the airbag light isn't on (no faults in the system), you don't need to disconnect the battery, just make sure the ignition is off when removing or installing the airbags. That said, disconnecting the battery certainly won't hurt a thing.
You know what, live and learn as the old saying goes. Do as you feel comfortable with. Take care.That is the correct procedure if you have an SRS fault code (airbag malfunction light on). Just above this procedure (at least in my 2016 factory manual) it states that if there is NO fault code, then the battery does not need to be disconnected before removing airbag components.. Of course, disconnecting the battery anyway certainly won't hurt a thing.......
