help getting half shaft out
kcc0521
Falls Church VA
Bo
2015 Black GT PP
I am trying to get my half shaft out and it seems stuck. How did you guys get the shaft to come out. I am super cautious because I have not done one before. Any help you have to offer would be greatly appreciated.
GTBOB
Fairfield Township, OHIO
Bob
'18 GT, Royal Crimson, 10 speed, Active Exhaust
Never done it but I'm pretty you have to use a pry bar to get them out of the differential. I believe there is a small clip on the splines that keeps tension on the half shaft.
kcc0521
Falls Church VA
Bo
2015 Black GT PP
I was scared to pry because it was a ridge on the diff that looked like a seal
GTBOB
Bob
Pry like this:
EXP Jawa
Rochester, NY
www.torsen.com
Rick
1999 Cobra Convertible, Electric Green
That's pretty much how you have to do it - if you try the pull/yank method (assuming the shaft was intact), you risk pulling the joint apart internally - which I've done more than once over the years.
There is a snap ring on the end of the shaft that expands into a groove in the differential's side gear. It is designed to require a defined amount of force applied before it can be pulled out; I don't recall the number at the moment. But that's what keeps the axle shaft from walking out of position on its own.
IvanCRF
El Paso, Texas
5.On'ry
Please post a picture of the failed half-shaft if you have a chance.
kcc0521
Falls Church VA
Bo
2015 Black GT PP
This is how I suggest as well, but you can also use two prybars on either side of the axle to distribute the forces more evenly.
I will try that tonight. It is a tight space in there. Thanks for all the help.
