IvanCRF
- Feb 19, 2015
- El Paso, Texas
- 5.On'ry
Hi guys,
I barely wrapped up installing my new Ford Racing half shafts.
I need your expertise on what to do with a rubber boot on the passenger side which rubs the shock whether the suspension is loaded or not.
I don't want to drive around and wear out the rubber boot like this. The driver's side is almost rubbing, but doesn't rub because it has a slight clearance of about 1/16'' when loaded. I clocked the bushings for both sides and tightened everything up.
Thank you,
Ivan
Driver's side:
Passenger side:
Thank you,
Ivan
Driver's side:
Passenger side:
