Torinate
Real world example - Turbo car left lane making 2 psi less then my supercharged car in the right lane. Turbo car trap’d 151mph & some change that day to my best of 147 mph. Same fuel and all other variables very similar. Turbo car makes mo PWR with less boost - end of thread.
great you said this, this is what i was taught a long time ago.
Your lungs would just be a blower and not a compressor. A turbo physically compresses the air as it passes through it. It isn't just merely moving it from one place to another like your lungs would. A roots style supercharger has no internal compression much like your lungs. Any compression that takes place is within the manifold or engine itself. If we take 2 different sized roots superchargers and installed them on an engine, if we had 10 psi with both, we'd also have the same flow with both. 1PSI = 1LB force per square inch (not Pounds of air per square inch!) - think about it, a square inch is a unit of area, not volume. 10 PSI = ten pound of force exerted exerted on every square inch of internal surface area of the intake manifold and intake ports = says nothing about how much air is in the intake/engine ( if it did it would be per cubic inch) just how much force the air is exerting as it gets force fed from the turbo's compressor.
Wow. Ok.
There are 100 reasons why the turbo car trapped 4 mph more. Is that 370 hp worth though? Maybe a turbo car does make more total power through a quarter mile pass. Look at power and boost at shift points etc. and drop off. Average power at all the rpm used in the run averaged out. Not disputing that. In your example, if the turbo car made 750 hp to your 800 hp peak and he beat you, makes complete sense. If he’s dropping to 4500 at shift but still has an available 600 Hp there and you’re dropping to 4500 at shift but “only” make 500 there, he will have the higher average hp even though your peak is higher.
Next. A turbo DOES NOT compress air inside it! Neither does a centrifugal blower or a roots blower. They compress air in the intake stream and rely on the spinning nature of the impeller to create the boost in the intake tract. A twin screw does though. It compresses inside the housing itself. The turbo cold side is very very similar (not exact though) as the centrifugal blower. Instead though, the turbo uses wxhaist gases to spin the impeller and a centrifugal uses a belt to spin it.
