It's the compressor turning on and off as it cycles...just like a typical car with climate control. Nothing abnormal just normal because they are ventilated seats not a wire that heats up inside the seats.That doesn't sound right...
Lol... to my knowledge, it does not work off a compressor... an electrothermal block is how the heat and cold is created.... much like the ones used on cpu coolers... one side is hot the opposite is coldIt's the compressor turning on and off as it cycles...just like a typical car with climate control. Nothing abnormal just normal because they are ventilated seats not a wire that heats up inside the seats.
Learn something new everyday. Still, I'm sure that electrothermal block makes some kind of noise if it has moving parts such as a fan to move the air....Lol... to my knowledge, it does not work off a compressor... an electrothermal block is how the heat and cold is created.... much like the ones used on cpu coolers... one side is hot the opposite is cold
There is only fans that pass the air by the block... there is absolutely no moving parts to an electrothermal block... it uses two dissimilar metals... when electricity is introduced... one side is hot, the other cold.Learn something new everyday. Still, I'm sure that electrothermal block makes some kind of noise if it has moving parts such as a fan to move the air....
The air in the seat is definitely cooled... I got out of the gym .. it was almost 80 out... turned on the cooled seats... definitely had cold air blowing through... it actually got too cold where I had to turn them off... it starts in high mode, 2 more presses bring it to mid and low cooling.... same with heatI thought that the heated/cooled seats used a fan blowing through an electric heater element for heat and just the fan to circulate air for 'cooling'. One of the first new owners, I believe, confirmed this.
The few times I used mine... were pretty quietOP said heated seats, not cooled, could be completely different.
Anyway, I attempted to take delivery of my car and there was a constant noise coming from inside the dash. And when the heated seats were on it cycles changing pitch and getting a lot louder. Set for cooled it just stayed the same as when the seats were off.
The constant noise was like a very high pitch squeal but it was loud enough to be annoying even when driving.
I didn't take delivery, they are supposed to let me know on Monday what is wrong and hopefully when it will be fixed.
