Hard to shift into 1st gear from stop
G8rbcn
Marietta Georgia
Scott
2017 Shelby GT350, BMW X5 and Audi A5 SB
Recently I have had several instances of my car not shifting into first gear from a stop. Some details:
1. Car is a 2017 with 11k miles. Installed a MGW shifter about a year and half ago. Love it!
2. This issue usually happens when the car is warm/hot. Not on cold start.
3. Has happened after shifting out of reverse when manuevering in a parking lot.
4. No other shifter/transmission issues (smooth shifts, no other noises)
Thoughts?
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
Sounds like that mgw shifter needs a little adjustment. Make the adjustment when the trans is at operating temperature.
jvandy50
H3249
AR
jason
23 Bronco, 18 ZL1-1LE
So these things are known for vibrating...any chance that reverse lockout could’ve moved?
Dominant1
Dr Frankenstang
Its possible..
DrumReaper
South East
Thoughts?
Call George at MGW... if it’s the shifter, he’ll let you know.
Threebanger
I am legend.
The Dirty South
Bray
2020 Twister Orange GT350
Your reverse lockout might be a little too close.
UXXR
Dirty South, USA
2018 Shelby GT350
I have a standard transmission and I have this issue from time to time as well. First gear is a little rough to get in. There were instances where I thought the car was in gear, but wasn't - made a cringeworthy khhhh noise.
When I posted that here, I was told by members that I wasn't alone, the transmission needed manhandling sometimes. It's not always, but half of the time, first gear needs some forcing. So, it might not be your short shifter, it might be the good ol Tremec.
DrumReaper
South East
Did you do the recall?
UXXR
Dirty South, USA
2018 Shelby GT350
Nope.. I have a 2018, and at that time when I checked, it wasn't part of the recall. When I went to dealer for maintenance, they didn't tell me a recall either.
Also, my problem is not necessarily going from reverse into 1st. This rough first gear engagement happens when you sit on traffic lights as well.
DrumReaper
South East
Well you have two options...
1) replace the shifter,
2) let the dealer assess it for a warranty fix.
If it were me, I’d go option #1 with an MGW shifter.
UXXR
Dirty South, USA
2018 Shelby GT350
I agree. The dealer taking the shifter-trans apart to look around gives me anxiety. MGW might be the solution to try first for couple hundred dollars.
OP, sorry for hijacking your thread for a minute : )
DrumReaper
South East
I think you’re making the right choice. George stands behind his product and his service is second-to-none.
The differences btw the MGW shifter and the stock shifter are night and day. You will appreciate the quality that George puts into his product.
NoXiDe
GA
GT350
I will occasionally have this issue myself too. I've learned if I either double clutch or wiggle the shifter left and right a few times that it will allow it to go into first. I also have the MGW and I believe it's a behavior on tremec's side. Who knows.. may be the fluid since its 30K miles but it will be interesting to see what it will be like when I swap to my track transmission. Would be interesting to see if the issue carries over.
foolwithtools
Ohio
2020 GT350
I have the opposite problem. Sometimes my transmission doesn't want to go all the way into reverse from 1st. If I go back into first and move the car forward a few inches in first, and then try to shift into reverse it goes all the way into reverse with no problems.
NoXiDe
GA
GT350
This happens to me too. Not often but I chalked it up to the nature of the tremec.
