#GT500 on Steeda Dual Rate Springs!
tj@steeda
Timothy
There is something special about a modified #GT500 on Steeda Dual Rate Springs!
GT500 Dual Rates - check them out here
Brisvegas
Brisbane
Pete
Dark Matter Grey '23 GT Mustang , 1976 SS Torana
Dual Rate on a Race car , hard pass
webspoke
Pilot Point, TX
Stan
2022 GT500 Code Orange
Don’t knock it until you try it. I switched from linear rates to the steeda duals, and you cannot feel any transition change. The softer rate is pretty much fully blocked out at ride height, like the factory cftp springs which are also duals. And you get the benefit of higher main rate for this heavy car.
tj@steeda
tj@steeda
Timothy
We are here when you are ready :)
Gt350procharged
South Florida
2018 gt350 proxharged
Just got the Steeda dual rates installed on my 21 GT500.....drives like oem on the street and handles better on turns.....need to try them on the track now to test it out......but the stance is perfect lowers the height just right.
Torchy
Vegas
2013 Mustang GT
Looks great! Did you use the rear shim?
Gt350procharged
South Florida
dont think so ...Steeda installed the springs and the steeda camber plates ......and removed the oem front camber plates...they aligned it for track specs -2.5 camber fronts and -1.7 rears
