GT350R Springs for GT (high rate, minimum lowering)
CrazedAntelope
San Jose, CA
Chad
Ecoboost Premium PP
I would agree with you that harshness comes from the rear. I'll try turning the rear rebound down. Currently at +3 compression and +6 rebound. I'm just afraid of being oversprung and underdamped. At this point I have a bunch of springs (4 sets) at my disposal it's just a matter of swapping in and out.
The car felt awesome confident and comfortable on the street with 780 rear spring rate and the shocks at a much firmer setting. But I'm sure the current setting outperforms it in HPDE. I'm hoping the 880 rear will be a happy medium.
A lot of this is just to satisfy my own curiosity :)
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
I would turn the front rebound down along with the rear. Try a reduction of 2 or 3 and see how it feels. When you go over a drop-off/curb/uneven pavement, the shocks want to keep the wheels were they are rather than letting the spring rate and gravity keep it on the ground. In the front, this means the car just falls rather than the wheel falling to meet the ground.
The upside of firm rebound is excellent sprung mass control as it will have resistance to roll and quick reaction, but it can make street manners trying at times.
CrazedAntelope
San Jose, CA
Chad
Ecoboost Premium PP
Thanks brotha. I will also do some reading up on Eibach vs GT350 vs PP rear swaybar.
BmacIL
Enginerd
Naperville, IL
Today was my first autocross (and a rain-soaked one at that!) since I did all this:
CB005
GT350R/SP085 springs
Pro Action dampers
Wheels and Tires
Billet Shock mounts
WOW. Even in the wet this car was brilliant. I think I will want to add a little more front camber to cure a smidge of mid-corner understeer (only at -1.5 now). Time for camber plates! I also have BMR RLCA bearings on the way, so that will only make it better
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
Nice.
You might want somebody to get some good head-on pictures of cornering to help guide your camber choices.
Norm
ansibe
Toronto
2016 GT PP, Recaros, Koni Yellow, 350r springs.
CB005
Pro Action dampers
Wheels and Tires
Billet Shock mounts
Great news! Any trouble putting the power down? I realize it was raining - mine spins in 2nd going straight!
Camber plates are a great idea, and I think I'll get the MM ones for mine. But, with more grip in the dry the front end may gain traction faster than the rear. You're running a pretty stiff rear spring, so once the body starts to roll, it's pretty likely the front will roll more than the rear. The added neg camber from roll might solve your mid corner understeer. One caveat: I like a bit of understeer in a car this powerful, so I'm biased.
BmacIL
Enginerd
Naperville, IL
Nice.
Norm
I normally use chalk on the sidewall and temp gauge after runs to check that
BmacIL
Enginerd
Naperville, IL
I actually ran in first! The course was tight and with the rain you couldn't go faster than 1st gear allows anyway. Other than when I was overdriving a little, it put power down really, really well. Very predictable.
I also like a little bit of understeer for this kind of car. Easy to neutralize with throttle.
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
So I have been testing out some stuff for a while now.
Thinking about offering a 7/8" ISH front drop Linear spring in the 250lb/in neighborhood....
This would make a BMR spring combo something like:
250lb/in Front Linear (7/8" Drop)
980lb/in Rear Linear (1/2" Drop)
Seems like this would be a homerun. Agree?
BmacIL
Enginerd
Naperville, IL
Agreed. :thumbsup:... They'd be on my car if they existed in December!
strengthrehab
Houston
Ken
2016 DIB Base GT with PP
Could this be well-paired with the FP Track dampers?
BmacIL
Enginerd
Naperville, IL
BMR Tech
Tampa, FL
Dion
You guys keep in mind. Don't let the massive spring rates out back scare you.
It honestly doesn't take much to control these high rates in the back, with that .49X~ motion ratio.
BmacIL
Enginerd
Naperville, IL
