CrazedAntelope
- Jul 12, 2015
- San Jose, CA
- Chad
- Ecoboost Premium PP
Hey Guys,
I wanted to give my initial feedback based on some posts earlier in this thread. I just had a shop install my BMR SP085 (980lb/in) in the rear along with my BMR spherical RLCA bearing and the FP toe-knucle bearing. I kept my front spring rates the same at 250in/lb on my ecoboost.
Old Rear Setup:
BC racing Spring + spring perch (784lb/in)
Stock RLCA bushing and toe-knuckle bushing
BMR CB005
Rear Eibach swaybar set to medium
JRZ shocks at +6compression, +5rebound
New Rear Setup:
BMR SP085 rear spring (980lb/in. Sits about 3/8" lower than the BC spring)
BMR RLCA bearing and FP toe-knuckle bearing
BMR CB005
Rear Eibach swaybar set to full soft
JRZ shocks at +3compression, +6rebound (manufacturer reccomendation for street)
The old setup was quite excellent for the street manners and confidence inspiring over bumps, but tended to understeer on corner entry and prematurely oversteer while exiting a corner. (Something I could only feel on Autocross)
With the new springs and bearings, the car was pretty much undrivable on the previous shock setting. The car was very uncomfortable and my back was hurting by the end of my 15 mile commute. I had to turn the compression way down and now it's sort of comfortable. Now it seems to be a little floaty over larger bumps in the road. However, overall handling balance is much improved and it seems I can get on the power earlier on corner exit (combo of increased confidence in the rear, less deflection of the bearings, and the softer swaybar offset by stiffer springs).
Of course, the JRZ's have the spherical mount at the top and bottom which everybody has been raving about, so there's no lack of articulation there. I did mention the new BMR springs sit lower, but I think I still am good on suspension travel. Attached is a picture of my compression shock travel when the car is resting on its own weight. It seems like I have 1.75" of travel compression before hitting the bumpstop.
We'll have to see what sort of shock tuning I can do from here. Maybe I'll add a small spring spacer just for better rear geometry, and to get that much further away from the bumpstop. But I'm still not completely sold on the new setup... these are stiff springs and I've removed/locked out quite a lot of mushy rubber from the rear suspension. Maybe I'll have to suck it up and drop down to the Steeda Ultralite Rear spring which is 880lb/in instead.
Please let me know if there is anything I could be overlooking! Does removing a lot of rubber mean I can run softer springs or does that mean I should run stiffer springs?
Old Rear Setup:
BMR CB005
New Rear Setup:
BMR CB005
